Traumatic
Message 11 of 96
Re: Noise margin reset please
Sorry I missed your call.
Thanks for resetting the line, will let you know how it goes.
Previously on the recomended BT line test, it said we could only get 2 meg but we were acheieving 6-8 on copper.
Now it says we can get 8 meg with fibre, so would the speed actually be more?
Also, we have had a lot of line issues previously with the line erroring and interference which bt couldn't resolve. Would a swap to fibre remove all of that?
Is fibre the way to go for a more stable line?
Moderator
Moderator
Message 12 of 96
Hi @Traumatic I called earlier to check how your connection is and left a voicemail message.
Can you post back and let me know how your connection has been since the SNR reset.
I checked the potential line speed for the Faster broadband on the line and it is only returning up to 3meg so the copper connection should potentially provide a better speed.
Cheers
John
Traumatic
Message 13 of 96
What I'm saying , is:
before the Exchange was upgraded that test only said 2 meg!
is there anyway to have a trial run on fibre due to the past problems on the line?
in the last 30 minutes, the line has reset every minute.
i think the most the line hasn't disconnected for is just under 2 days
Moderator
Moderator
Message 14 of 96
Hi @Traumatic I called earlier and left a voicemail. If you want to go ahead with the upgrade to the Faster broadband then i'm happy for you to try this.
Cheers
John
Traumatic
Message 15 of 96
Hi John,
Provisionally i'd want to try this. pricing, I see there are 2 packages? But the faster one doesn't say about download allowance.
Would you be able to look into the pricing?
Probably best if you call
Moderator
Moderator
Message 16 of 96
Hi @Traumatic I just gave you a quick call there sorry I missed you. Are you available tomorrow to take a call from me. I am in from 1pm - 8.30pm.
In the meantime time I have checked and only have an Unlimited Faster Broadband Service available to order.
Cheers
John
Traumatic
Message 17 of 96
I should be available then, sorry I keep missing you!
I've put your number in my phone!
It's comes up if I was a new customer ordering ( both broadband packages) Can speak tomorrow about it anyway!
Traumatic
Message 18 of 96
We're currently paying £34.99, as we recently signed a new contract to avoid paying an out of contract surcharge amount for BT Sport
First picture is if I was a new customer, 2nd picture is the upgrade deal
Traumatic
Message 19 of 96
How do I find the line stats on the bt smart hub?
As this new hub seems to have crippled the line
XRaySpeX
Recognised Expert
Message 20 of 96
Post your Home Hub router stats
Learn how from here Broadband Top Tips
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
