Message 21 of 96
Re: Noise margin reset please
@Traumatic wrote:
How do I find the line stats on the bt smart hub?
As this new hub seems to have crippled the line
You posted them on this post https://community.bt.com/t5/ADSL-Copper-Broadband-Speed/Noise-margin-reset-please/m-p/1770427#M26671...
The smart hub is not the best to use on ASDL due to its wide signal bandwidth.
Traumatic
Message 22 of 96
I know I posted them earlier, that was on a home hub 3.
Which I'm told doesn't work with Fibre?
As the Fibre starts tomorrow, I want to see what speeds / noise margin I'm getting. But I'm on the latest hub
Traumatic
Message 23 of 96
Traumatic
Message 24 of 96
@JohnC2
Do you know when the fibre will be activated today?
Message 25 of 96
It can happen at any time up to midnight
Message 26 of 96
Wrong.
It can happen anytime until about 6pm (that's when the engineers finish work).
Message 27 of 96
have had a friend who was activated at 2200 when wholesale finished the software build
Traumatic
Message 28 of 96
If I'm on fibre, looks like I need to be changed back to what i was on before.
googling the modulation says I'm on ADSL 2 though!?
Dont really understand how it can be so much slower!
ill try my other modem and see if that does any better
Message 29 of 96
Post edited, as I misread the results Smiley Sad
XRaySpeX
Recognised Expert
Message 30 of 96
What's going on here? G.993.2 is VDSL2 Fibre. OP is getting half what he was on ADSL2+.
From the Attenuation this looks like an EO line where a cab. has been built outside exchange.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
