Message 31 of 96
Re: Noise margin reset please
@XRaySpeX wrote:
What's going on here? G.993.2 is VDSL2 Fibre. OP is getting half what he was on ADSL2+.
Post deleted, as I misread the information.
I agree that the speed is much worse now. Its gone from 6.2Mbs to 3.03Mbs. It would be best to go back to ADSL2+.
Message 32 of 96
You are to far from the cabinet to benefit from fibre service
Message 33 of 96
Possibly.
Can you put your number into here https://www.dslchecker.bt.com and post up the results.
Moderator
Moderator
Message 34 of 96
Hi @Traumatic I have checked and Wholesale have corrected the records now. I'm not sure if this will improve the connection and as agreed I will check back with you tomorrow.
Cheers
John
Traumatic
Message 35 of 96
Moderator
Moderator
Message 36 of 96
Hi @Traumatic Sorry that the connection on faster broadband was worse. I have placed the order to change you back to the copper broadband and that will complete on the 12th September. I will check back with you on the 13th.
Cheers
John
Moderator
Moderator
Message 37 of 96
Hi @Traumatic I called earlier sorry I could not reach you. I wanted to check how your connection is now that you have been changed back to the copper broadband.
Post back and let me know how you are getting on.
cheers
John
Traumatic
Message 38 of 96
Hi John,
it's been resetting, but I can't see why.
i imagine it's something to do with fast latency? As the noise margin seems okay.IMG_4984.PNG
XRaySpeX
Recognised Expert
Message 39 of 96
It's now running on ADSL (G.992.1), not ADSL2+ (G.992.5) which should be faster. Are you able to switch ADSL Mode in the router?
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Traumatic
Message 40 of 96
As it's a BT router I highly doubt it
