Traumatic
Message 41 of 96
Re: Noise margin reset please
Noise margin is dropping too low.
XRaySpeX
Recognised Expert
Message 42 of 96
A NM of 3dB is fine on a stable line.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Traumatic
Message 43 of 96
I'm 1.5-2 miles from the exchange, 6 is okay, 7 seems the best
Message 44 of 96
Distance is irrelevant. I had 2dB on a 5km line
Traumatic
Message 45 of 96
Latency was supposed to of been changed, but it hasn't been.
Message 46 of 96
latency of infinity cannot be changed
XRaySpeX
Recognised Expert
Message 47 of 96
@john46: This is not Infinity, but ADSL, specifically ADSL Max.
Message 48 of 96
my apologies
Traumatic
Message 49 of 96
Your colleague was changing it to interleaved, but the change hasn't been made.
Traumatic
Message 50 of 96
Nothing has changed from my last message. Seems it's still dropping and latency is still on fast
