Moderator
Moderator
Message 51 of 96
Re: Noise margin reset please
@Traumatic I'm sorry about that, I've left a message with @JohnC2 to let him know that you've posted.
Moderator
Moderator
Message 52 of 96
Hi @Traumatic Sorry about the Interleaving it was showing as applied at our end. I have checked with BT Wholesale and it was not active and they have ordered the Interleaving to be applied now and this will complete within 24hrs.
Cheers
John
Traumatic
Message 53 of 96
Traumatic
Message 54 of 96
As of now, it's still hasn't changed.
Moderator
Moderator
Message 55 of 96
Thanks @Traumatic.
I'll let @JohnC2 know that you were in touch.
DanielS
Traumatic
Message 56 of 96
Traumatic
Message 57 of 96
I've just tried ringing on the house phone and there is a constant sound . It sounds like the sound the sea makes.
That's the best way to describe the sound
Moderator
Moderator
Message 58 of 96
Hi @Traumatic I called earlier and left a brief message. Thanks for posting an update. The noise interference on the line is probably the cause of your broadband fault. Please can you test you telephone directly in the test socket and see if the noise persists and if so please try a 2nd phone also to ensure the phone is not faulty.
cheers
John
Moderator
Moderator
Message 59 of 96
Hi @Traumatic I called earlier and left a voice mail; sorry I missed you. Have you been able to locate the cause of the noise on the line? Post back and let me know how you are getting on.
Cheers
John
Traumatic
Message 60 of 96
