DiggerOfTrenches
Message 1 of 22
PPP Dropouts during day. remote station is not answering to LCP Echo requests
Hello,
Had two PPP dropouts during the day, not mainainance?, one with resync one without. Edit. Read own logs correctly!
Had a PPP dropout without resync during day.
This has been ocouring since January was mixed in with outages due to damaged underground cable now repaired.
I need to trawl archived loggs to be more specific.  Simular times as well. Any ideas?
Tags (1)
21 REPLIES 21
DiggerOfTrenches
Message 2 of 22
Re: PPP Dropouts during day. remote station is not answering to LCP Echo requests
And not quite the same but different PPP dropout.
DiggerOfTrenches
Message 3 of 22
And this one. All the same?
12:07:54, 04 Apr. NTP synchronization success
12:07:41, 04 Apr. NTP synchronization start
12:07:40, 04 Apr. WAN connection ATM connected
12:07:39, 04 Apr. PPP IPCP Receive Configuration ACK
12:07:39, 04 Apr. PPP IPCP Send Configuration Request
12:07:39, 04 Apr. PPP IPCP Receive Configuration NAK
12:07:39, 04 Apr. PPP IPCP Receive Configuration Reject
12:07:39, 04 Apr. PPP IPCP Send Configuration ACK
12:07:38, 04 Apr. PPP IPCP Receive Configuration Request
12:07:38, 04 Apr. PPP IPCP Send Configuration Request
12:07:38, 04 Apr. PPP CHAP Receive success : authentication successful
12:07:38, 04 Apr. PPP CHAP Receive Challenge
12:07:38, 04 Apr. PPP LCP Send Configuration ACK
12:07:38, 04 Apr. PPP LCP Receive Configuration Request
12:07:37, 04 Apr. PPP LCP Receive Configuration ACK
12:07:37, 04 Apr. PPP LCP Send Configuration Request
12:07:34, 04 Apr. PPP LCP Receive Configuration ACK
12:07:34, 04 Apr. PPP LCP Send Configuration Request
12:07:31, 04 Apr. DSL Link Up: Down Rate=2336Kbps, Up Rate=448Kbps; SNR Margin Down=6.6dB, Up=17.0dB
12:06:54, 04 Apr. DSL Link Down: duration was 170171 seconds
12:06:29, 04 Apr. PPP LCP Send Configuration Request
12:06:26, 04 Apr. PPP LCP Send Configuration Request
12:06:23, 04 Apr. PPP LCP Send Configuration Request
12:06:20, 04 Apr. PPP LCP Send Configuration Request
12:06:17, 04 Apr. PPP LCP Send Configuration Request
12:06:14, 04 Apr. PPP LCP Send Configuration Request
12:06:10, 04 Apr. PPP LCP Send Configuration Request
12:06:07, 04 Apr. PPP LCP Send Configuration Request
12:06:04, 04 Apr. PPP LCP Send Configuration Request
12:06:01, 04 Apr. PPP LCP Send Configuration Request
12:06:00, 04 Apr. WAN connection ATM disconnected
12:05:52, 04 Apr. PPP LCP Send Termination Request (User request)
12:05:49, 04 Apr. PPP LCP Send Termination Request (Peer not responding)
12:00:41, 04 Apr. admin login success from 192.168.1.190
09:18:26, 04 Apr. Receive a DHCP request
DiggerOfTrenches
Message 4 of 22
00:54:31, 02 Apr. NTP synchronization success
00:54:18, 02 Apr. NTP synchronization start
00:54:16, 02 Apr. WAN connection ATM connected
00:54:16, 02 Apr. PPP IPCP Receive Configuration ACK
00:54:16, 02 Apr. PPP IPCP Send Configuration Request
00:54:16, 02 Apr. PPP IPCP Receive Configuration NAK
00:54:15, 02 Apr. PPP IPCP Receive Configuration Reject
00:54:15, 02 Apr. PPP IPCP Send Configuration ACK
00:54:15, 02 Apr. PPP IPCP Receive Configuration Request
00:54:15, 02 Apr. PPP IPCP Send Configuration Request
00:54:15, 02 Apr. PPP CHAP Receive success : authentication successful
00:54:15, 02 Apr. PPP CHAP Receive Challenge
00:54:14, 02 Apr. PPP LCP Send Configuration ACK
00:54:14, 02 Apr. PPP LCP Receive Configuration Request
00:54:14, 02 Apr. PPP LCP Receive Configuration ACK
00:54:14, 02 Apr. PPP LCP Send Configuration Request
00:54:12, 02 Apr. PPP LCP Receive Configuration ACK
00:54:11, 02 Apr. PPP LCP Send Configuration Request
00:54:08, 02 Apr. DSL Link Up: Down Rate=2848Kbps, Up Rate=448Kbps; SNR Margin Down=6.9dB, Up=16.0dB
00:53:34, 02 Apr. PPP LCP Send Termination Request (User request)
00:53:31, 02 Apr. PPP LCP Send Termination Request (User request)
00:53:31, 02 Apr. DSL Link Down: duration was 309552 seconds
00:53:30, 02 Apr. PPP LCP Send Configuration Request
00:53:29, 02 Apr. WAN connection ATM disconnected
00:53:21, 02 Apr. PPP LCP Send Termination Request (User request)
00:53:18, 02 Apr. PPP LCP Send Termination Request (Peer not responding)
21:17:51, 01 Apr. Receive a DHCP request
13:21:38, 01 Apr. admin login success from 192.168.1.190
DiggerOfTrenches
Message 5 of 22
09:49:26, 29 Mar. NTP synchronization success
09:49:12, 29 Mar. NTP synchronization start
09:49:10, 29 Mar. WAN connection ATM connected
09:49:10, 29 Mar. PPP IPCP Receive Configuration ACK
09:49:10, 29 Mar. PPP IPCP Send Configuration Request
09:49:10, 29 Mar. PPP IPCP Receive Configuration NAK
09:49:09, 29 Mar. PPP IPCP Send Configuration Request
09:49:09, 29 Mar. PPP IPCP Receive Configuration Reject
09:49:09, 29 Mar. PPP IPCP Send Configuration ACK
09:49:09, 29 Mar. PPP IPCP Receive Configuration Request
09:49:09, 29 Mar. PPP CHAP Receive success : authentication successful
09:49:08, 29 Mar. PPP CHAP Receive Challenge
09:49:08, 29 Mar. PPP LCP Send Configuration ACK
09:49:08, 29 Mar. PPP LCP Receive Configuration Request
09:49:08, 29 Mar. PPP LCP Receive Configuration ACK
09:49:08, 29 Mar. PPP LCP Send Configuration Request
09:49:05, 29 Mar. PPP LCP Receive Configuration ACK
09:49:04, 29 Mar. PPP LCP Send Configuration Request
09:49:01, 29 Mar. DSL Link Up: Down Rate=2112Kbps, Up Rate=448Kbps; SNR Margin Down=6.6dB, Up=15.0dB
09:48:23, 29 Mar. PPP LCP Send Termination Request (User request)
09:48:20, 29 Mar. PPP LCP Send Termination Request (User request)
09:48:19, 29 Mar. DSL Link Down: duration was 5344 seconds
09:48:19, 29 Mar. Restart Button Release
09:48:17, 29 Mar. PPP LCP Send Configuration Request
09:48:15, 29 Mar. Restart Button Press
09:48:14, 29 Mar. PPP LCP Send Configuration Request
09:48:13, 29 Mar. Restart Button Release
09:48:12, 29 Mar. Restart Button Press
09:48:11, 29 Mar. PPP LCP Send Configuration Request
09:48:08, 29 Mar. PPP LCP Send Configuration Request
09:47:34, 29 Mar. PPP LCP Send Configuration Request
09:47:31, 29 Mar. PPP LCP Send Configuration Request
09:47:28, 29 Mar. PPP LCP Send Configuration Request
09:47:25, 29 Mar. PPP LCP Send Configuration Request
09:47:22, 29 Mar. PPP LCP Send Configuration Request
09:47:18, 29 Mar. PPP LCP Send Configuration Request
09:47:15, 29 Mar. PPP LCP Send Configuration Request
09:47:12, 29 Mar. PPP LCP Send Configuration Request
09:47:09, 29 Mar. PPP LCP Send Configuration Request
09:47:06, 29 Mar. PPP LCP Send Configuration Request
09:46:32, 29 Mar. PPP LCP Send Configuration Request
09:46:29, 29 Mar. PPP LCP Send Configuration Request
09:46:26, 29 Mar. PPP LCP Send Configuration Request
09:46:23, 29 Mar. PPP LCP Send Configuration Request
09:46:19, 29 Mar. PPP LCP Send Configuration Request
09:46:16, 29 Mar. PPP LCP Send Configuration Request
09:46:13, 29 Mar. PPP LCP Send Configuration Request
09:46:10, 29 Mar. PPP LCP Send Configuration Request
09:46:07, 29 Mar. PPP LCP Send Configuration Request
09:46:04, 29 Mar. PPP LCP Send Configuration Request
09:45:30, 29 Mar. PPP LCP Send Configuration Request
09:45:27, 29 Mar. PPP LCP Send Configuration Request
09:45:24, 29 Mar. PPP LCP Send Configuration Request
09:45:21, 29 Mar. PPP LCP Send Configuration Request
09:45:18, 29 Mar. PPP LCP Send Configuration Request
09:45:15, 29 Mar. PPP LCP Send Configuration Request
09:45:11, 29 Mar. PPP LCP Send Configuration Request
09:45:08, 29 Mar. PPP LCP Send Configuration Request
09:45:05, 29 Mar. PPP LCP Send Configuration Request
09:45:02, 29 Mar. PPP LCP Send Configuration Request
09:45:01, 29 Mar. WAN connection ATM disconnected
09:44:51, 29 Mar. PPP LCP Send Termination Request (User request)
09:44:48, 29 Mar. PPP LCP Send Termination Request (Peer not responding)
09:40:58, 29 Mar. admin login success from 192.168.1.190
09:21:56, 29 Mar. admin login success from 192.168.1.190
09:00:14, 29 Mar. admin login success from 192.168.1.190
08:20:31, 29 Mar. CWMP: HDM socket closed successfully.
08:20:31, 29 Mar. CWMP: HTTP authentication success from pbthdm.x.x.x
08:20:31, 29 Mar. CWMP: HDM socket opened successfully.
08:20:31, 29 Mar. CWMP: session completed successfully
08:20:30, 29 Mar. CWMP: HDM socket opened successfully.
08:20:27, 29 Mar. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
08:20:27, 29 Mar. CWMP: Session start now, server: pbthdm.x.x.x, Event code:
08:20:27, 29 Mar. CWMP: Initializing transaction for event code 4 VALUE CHANGE
08:20:18, 29 Mar. CWMP: HDM socket closed successfully.
08:20:18, 29 Mar. CWMP: HTTP authentication success from pbthdm.x.x.x
08:20:18, 29 Mar. CWMP: HDM socket opened successfully.
08:20:17, 29 Mar. CWMP: session completed successfully
08:20:17, 29 Mar. CWMP: HDM socket closed successfully.
08:20:17, 29 Mar. CWMP: HTTP authentication success from pbthdm.x.x.x
08:20:16, 29 Mar. CWMP: HDM socket opened successfully.
08:20:13, 29 Mar. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
08:20:13, 29 Mar. CWMP: Session start now, server: pbthdm.x.x.x, Event code:
08:20:13, 29 Mar. CWMP: Initializing transaction for event code 1 BOOT
08:19:39, 29 Mar. NTP synchronization success
08:19:25, 29 Mar. NTP synchronization start
08:19:23, 29 Mar. WAN connection ATM connected
08:19:23, 29 Mar. PPP IPCP Receive Configuration ACK
08:19:23, 29 Mar. PPP IPCP Send Configuration Request
08:19:23, 29 Mar. PPP IPCP Receive Configuration NAK
08:19:22, 29 Mar. PPP IPCP Send Configuration Request
08:19:22, 29 Mar. PPP IPCP Receive Configuration Reject
08:19:22, 29 Mar. PPP IPCP Send Configuration ACK
08:19:22, 29 Mar. PPP IPCP Receive Configuration Request
08:19:22, 29 Mar. PPP CHAP Receive success : authentication successful
08:19:22, 29 Mar. PPP CHAP Receive Challenge
08:19:21, 29 Mar. PPP LCP Receive Configuration ACK
08:19:21, 29 Mar. PPP LCP Send Configuration ACK
08:19:21, 29 Mar. PPP LCP Receive Configuration Request
08:19:21, 29 Mar. PPP LCP Send Configuration Request
08:19:18, 29 Mar. PPP LCP Receive Configuration ACK
08:19:18, 29 Mar. PPP LCP Send Configuration Request
08:19:15, 29 Mar. DSL Link Up: Down Rate=2720Kbps, Up Rate=448Kbps; SNR Margin Down=6.2dB, Up=14.0dB
08:18:43, 29 Mar. PPP LCP Send Termination Request (User request)
08:18:40, 29 Mar. PPP LCP Send Termination Request (User request)
08:18:40, 29 Mar. DSL Link Down: duration was 20 seconds
08:18:37, 29 Mar. PPP IPCP Send Configuration Request
08:18:35, 29 Mar. 2.4G WiFi auto selected channel 1 Bandwidth:20M(Reason:boot)
08:18:34, 29 Mar. PPP IPCP Send Configuration Request
08:18:32, 29 Mar. 2.4G WiFi scan(Reason:boot)
08:18:31, 29 Mar. 5G WiFi auto selected channel 48 Bandwidth:40M(Reason:boot)
08:18:31, 29 Mar. PPP IPCP Send Configuration Request
08:18:31, 29 Mar. PPP IPCP Receive Configuration Reject
08:18:30, 29 Mar. PPP IPCP Send Configuration ACK
08:18:30, 29 Mar. PPP IPCP Receive Configuration Request
08:18:30, 29 Mar. PPP IPCP Send Configuration Request
08:18:30, 29 Mar. PPP CHAP Receive success : authentication successful
08:18:30, 29 Mar. PPP CHAP Receive Challenge
08:18:30, 29 Mar. PPP LCP Send Configuration ACK
08:18:29, 29 Mar. PPP LCP Receive Configuration Request
08:18:29, 29 Mar. PPP LCP Receive Configuration ACK
08:18:29, 29 Mar. PPP LCP Send Configuration Request
08:18:26, 29 Mar. PPP LCP Receive Configuration ACK
08:18:26, 29 Mar. PPP LCP Send Configuration Request
08:18:26, 29 Mar. 5G WiFi scan(Reason:boot)
08:18:20, 29 Mar. DSL Link Up: Down Rate=2720Kbps, Up Rate=448Kbps; SNR Margin Down=6.2dB, Up=15.0dB
08:18:09, 29 Mar. 5G WiFi auto selected channel 36 Bandwidth:40M(Reason:boot)
08:18:08, 29 Mar. Booting firmware v0.07.05.03230-BT (Fri Mar 23 19:56:07 2018)
08:18:08, 29 Mar. System start Button press (PowerButton)
08:18:04, 29 Mar. Device Connected: 192.168.1.190, 60:03:47:2e:cf:b4, unknown
08:18:02, 29 Mar. 5G WiFi scan(Reason:boot)
08:18:02, 29 Mar. DHCP Lease issued 192.168.1.190 to 60:03:47:2e:cf:b4 , lease duration is 86400 seconds
08:17:58, 29 Mar. Receive a DHCP request
08:17:56, 29 Mar. Receive a DHCP request
08:17:53, 29 Mar. Receive a DHCP request
08:17:50, 29 Mar. System up
08:17:46, 29 Mar. Wire Lan Port 2 up
08:17:35, 29 Mar. 2.4G WPS feature enabled
08:17:35, 29 Mar. 2.4G WPA/WPA2 mode selected
08:17:35, 29 Mar. 2.4G WiFi DOWN
08:17:35, 29 Mar. 5G WPS feature enabled
08:17:35, 29 Mar. 5G WPA2 mode selected
08:17:35, 29 Mar. 5G WiFi DOWN
08:17:34, 29 Mar. IPv6 Service: DHCP Server stop
08:17:34, 29 Mar. IPv6 Service: RA Server stop
08:16:09, 29 Mar. PPP LCP Receive Configuration ACK
08:16:09, 29 Mar. PPP LCP Send Configuration Request
08:16:06, 29 Mar. PPP LCP Send Configuration Request
08:16:02, 29 Mar. PPP LCP Send Configuration Request
08:15:59, 29 Mar. PPP LCP Send Configuration ACK
08:15:59, 29 Mar. PPP LCP Send Configuration Request
08:15:59, 29 Mar. PPP LCP Receive Configuration Request
08:15:31, 29 Mar. PPP LCP Receive Configuration ACK
08:15:31, 29 Mar. PPP LCP Send Configuration Request
08:15:28, 29 Mar. PPP LCP Send Configuration Request
08:15:25, 29 Mar. PPP LCP Send Configuration Request
08:15:25, 29 Mar. PPP LCP Send Configuration ACK
08:15:25, 29 Mar. PPP LCP Receive Configuration Request
08:15:22, 29 Mar. PPP LCP Send Configuration Request
08:14:48, 29 Mar. PPP LCP Send Termination Request (Peer not responding)
08:14:45, 29 Mar. PPP LCP Send Termination Request (Peer not responding)
08:13:25, 29 Mar. PPP LCP Receive Configuration ACK
08:13:25, 29 Mar. PPP LCP Send Configuration ACK
08:13:24, 29 Mar. PPP LCP Send Configuration Request
08:13:24, 29 Mar. PPP LCP Receive Configuration Request
08:13:13, 29 Mar. PPP LCP Receive Configuration ACK
08:13:13, 29 Mar. PPP LCP Send Configuration Request
08:13:10, 29 Mar. PPP LCP Send Configuration Request
08:13:07, 29 Mar. PPP LCP Send Configuration Request
08:13:03, 29 Mar. PPP LCP Send Configuration Request
08:13:00, 29 Mar. PPP LCP Send Configuration Request
08:12:57, 29 Mar. PPP LCP Send Configuration Request
08:12:54, 29 Mar. PPP LCP Send Configuration Request
08:12:51, 29 Mar. PPP LCP Send Configuration ACK
08:12:51, 29 Mar. PPP LCP Receive Configuration Request
08:12:51, 29 Mar. PPP LCP Send Configuration Request
08:12:48, 29 Mar. PPP LCP Send Configuration Request
08:12:14, 29 Mar. PPP LCP Send Configuration Request
08:12:11, 29 Mar. PPP LCP Send Configuration Request
08:12:08, 29 Mar. PPP LCP Send Configuration ACK
08:12:08, 29 Mar. PPP LCP Receive Configuration Request
08:12:08, 29 Mar. PPP LCP Send Configuration Request
08:12:05, 29 Mar. PPP LCP Send Configuration Request
08:12:02, 29 Mar. PPP LCP Send Configuration Request
08:11:59, 29 Mar. PPP LCP Send Configuration Request
08:11:56, 29 Mar. PPP LCP Send Configuration Request
08:11:52, 29 Mar. PPP LCP Send Configuration Request
08:11:49, 29 Mar. PPP LCP Send Configuration Request
08:11:46, 29 Mar. PPP LCP Send Configuration Request
08:11:43, 29 Mar. PPP LCP Receive Configuration ACK
08:11:43, 29 Mar. PPP LCP Send Configuration Request
08:11:40, 29 Mar. PPP LCP Send Configuration Request
08:11:39, 29 Mar. WAN connection ATM disconnected
08:11:33, 29 Mar. PPP LCP Receive Termination ACK
08:11:32, 29 Mar. PPP LCP Send Termination Request (Peer not responding)
06:46:31, 29 Mar. DoS(UDP Loopback): IN=ppp1 OUT= MAC= src=140.164.55 LEN=29 TOS=0x00
DiggerOfTrenches
Message 6 of 22
07:26:18, 27 Mar. NTP synchronization success
07:26:04, 27 Mar. NTP synchronization start
07:26:03, 27 Mar. WAN connection ATM connected
07:26:02, 27 Mar. PPP IPCP Receive Configuration ACK
07:26:02, 27 Mar. PPP IPCP Send Configuration Request
07:26:02, 27 Mar. PPP IPCP Receive Configuration NAK
07:26:02, 27 Mar. PPP IPCP Receive Configuration Reject
07:26:02, 27 Mar. PPP IPCP Send Configuration ACK
07:26:01, 27 Mar. PPP IPCP Receive Configuration Request
07:26:01, 27 Mar. PPP IPCP Send Configuration Request
07:26:01, 27 Mar. PPP CHAP Receive success : authentication successful
07:26:01, 27 Mar. PPP CHAP Receive Challenge
07:26:01, 27 Mar. PPP LCP Send Configuration ACK
07:26:01, 27 Mar. PPP LCP Receive Configuration Request
07:25:58, 27 Mar. PPP LCP Receive Configuration ACK
07:25:58, 27 Mar. PPP LCP Send Configuration Request
07:25:56, 27 Mar. WAN connection ATM disconnected
07:25:48, 27 Mar. PPP LCP Send Termination Request (User request)
07:25:45, 27 Mar. PPP LCP Send Termination Request (Peer not responding)
05:57:46, 27 Mar. Receive a DHCP request
DiggerOfTrenches
Message 7 of 22
08:16:58, 26 Mar. NTP synchronization success
08:16:44, 26 Mar. NTP synchronization start
08:16:43, 26 Mar. WAN connection ATM connected
08:16:42, 26 Mar. PPP IPCP Receive Configuration ACK
08:16:42, 26 Mar. PPP IPCP Send Configuration Request
08:16:42, 26 Mar. PPP IPCP Receive Configuration NAK
08:16:42, 26 Mar. PPP IPCP Receive Configuration Reject
08:16:42, 26 Mar. PPP IPCP Send Configuration ACK
08:16:41, 26 Mar. PPP IPCP Receive Configuration Request
08:16:41, 26 Mar. PPP IPCP Send Configuration Request
08:16:41, 26 Mar. PPP CHAP Receive success : authentication successful
08:16:41, 26 Mar. PPP CHAP Receive Challenge
08:16:41, 26 Mar. PPP LCP Send Configuration ACK
08:16:41, 26 Mar. PPP LCP Receive Configuration Request
08:16:40, 26 Mar. PPP LCP Receive Configuration ACK
08:16:40, 26 Mar. PPP LCP Send Configuration Request
08:16:38, 26 Mar. PPP LCP Receive Configuration ACK
08:16:37, 26 Mar. PPP LCP Send Configuration Request
08:16:34, 26 Mar. DSL Link Up: Down Rate=2272Kbps, Up Rate=448Kbps; SNR Margin Down=6.3dB, Up=17.0dB
08:16:00, 26 Mar. PPP LCP Send Termination Request (User request)
08:15:57, 26 Mar. PPP LCP Send Termination Request (User request)
08:15:56, 26 Mar. DSL Link Down: duration was 177 seconds
08:15:55, 26 Mar. PPP LCP Send Configuration Request
08:15:51, 26 Mar. PPP LCP Send Configuration Request
08:15:48, 26 Mar. PPP LCP Send Configuration Request
08:15:45, 26 Mar. PPP LCP Send Configuration Request
08:15:42, 26 Mar. PPP LCP Send Configuration Request
08:15:39, 26 Mar. PPP LCP Send Configuration Request
08:15:38, 26 Mar. WAN connection ATM disconnected
08:15:32, 26 Mar. admin login success from 192.168.1.190
08:15:29, 26 Mar. PPP LCP Send Termination Request (User request)
08:15:26, 26 Mar. PPP LCP Send Termination Request (Peer not responding)
08:14:17, 26 Mar. CWMP: HDM socket closed successfully.
08:14:17, 26 Mar. CWMP: HTTP authentication success from pbthdm.x.x.x
08:14:17, 26 Mar. CWMP: HDM socket opened successfully.
08:14:17, 26 Mar. CWMP: session completed successfully
08:14:16, 26 Mar. CWMP: HDM socket closed successfully.
08:14:16, 26 Mar. CWMP: HTTP authentication success from pbthdm.x.x.x
08:14:16, 26 Mar. CWMP: HDM socket opened successfully.
08:14:15, 26 Mar. CWMP: HDM socket opened successfully.
08:14:13, 26 Mar. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
08:14:12, 26 Mar. CWMP: Session start now, server: pbthdm.x.x.x, Event code:
08:14:12, 26 Mar. CWMP: Initializing transaction for event code 4 VALUE CHANGE
08:13:22, 26 Mar. NTP synchronization success
08:13:09, 26 Mar. NTP synchronization start
08:13:07, 26 Mar. WAN connection ATM connected
08:13:07, 26 Mar. PPP IPCP Receive Configuration ACK
08:13:07, 26 Mar. PPP IPCP Send Configuration Request
08:13:07, 26 Mar. PPP IPCP Receive Configuration NAK
08:13:06, 26 Mar. PPP IPCP Send Configuration Request
08:13:06, 26 Mar. PPP IPCP Receive Configuration Reject
08:13:06, 26 Mar. PPP IPCP Send Configuration ACK
08:13:06, 26 Mar. PPP IPCP Receive Configuration Request
08:13:06, 26 Mar. PPP CHAP Receive success : authentication successful
08:13:06, 26 Mar. PPP CHAP Receive Challenge
08:13:05, 26 Mar. PPP LCP Receive Configuration ACK
08:13:05, 26 Mar. PPP LCP Send Configuration ACK
08:13:05, 26 Mar. PPP LCP Receive Configuration Request
08:13:05, 26 Mar. PPP LCP Send Configuration Request
08:13:02, 26 Mar. PPP LCP Receive Configuration ACK
08:13:02, 26 Mar. PPP LCP Send Configuration Request
08:12:59, 26 Mar. DSL Link Up: Down Rate=2784Kbps, Up Rate=448Kbps; SNR Margin Down=6.5dB, Up=17.0dB
08:12:39, 26 Mar. WAN connection ATM disconnected
08:12:30, 26 Mar. PPP LCP Send Termination Request (User request)
08:12:27, 26 Mar. PPP LCP Send Termination Request (User request)
08:12:26, 26 Mar. DSL Link Down: duration was 56298 seconds
DiggerOfTrenches
Message 8 of 22
09:03:09, 24 Mar. NTP synchronization success
09:02:55, 24 Mar. NTP synchronization start
09:02:54, 24 Mar. WAN connection ATM connected
09:02:54, 24 Mar. PPP IPCP Receive Configuration ACK
09:02:54, 24 Mar. PPP IPCP Send Configuration Request
09:02:54, 24 Mar. PPP IPCP Receive Configuration NAK
09:02:53, 24 Mar. PPP IPCP Send Configuration Request
09:02:53, 24 Mar. PPP IPCP Receive Configuration Reject
09:02:53, 24 Mar. PPP IPCP Send Configuration ACK
09:02:53, 24 Mar. PPP IPCP Receive Configuration Request
09:02:53, 24 Mar. PPP CHAP Receive success : authentication successful
09:02:52, 24 Mar. PPP CHAP Receive Challenge
09:02:52, 24 Mar. PPP LCP Send Configuration ACK
09:02:52, 24 Mar. PPP LCP Receive Configuration Request
09:02:49, 24 Mar. PPP LCP Receive Configuration ACK
09:02:49, 24 Mar. PPP LCP Send Configuration Request
09:02:46, 24 Mar. DSL Link Up: Down Rate=3136Kbps, Up Rate=448Kbps; SNR Margin Down=6.5dB, Up=17.0dB
09:01:59, 24 Mar. PPP LCP Send Termination Request (User request)
09:01:56, 24 Mar. PPP LCP Send Termination Request (User request)
09:01:56, 24 Mar. DSL Link Down: duration was 526711 seconds
09:01:54, 24 Mar. PPP LCP Send Configuration Request
09:01:51, 24 Mar. PPP LCP Send Configuration Request
09:01:47, 24 Mar. PPP LCP Send Configuration Request
09:01:47, 24 Mar. WAN connection ATM disconnected
09:01:37, 24 Mar. PPP LCP Send Termination Request (User request)
09:01:34, 24 Mar. PPP LCP Send Termination Request (Peer not responding)
06:53:59, 24 Mar. NTP synchronization success
DiggerOfTrenches
Message 9 of 22
05:02:56, 18 Mar. NTP synchronization success
05:02:43, 18 Mar. NTP synchronization start
05:02:42, 18 Mar. WAN connection ATM connected
05:02:41, 18 Mar. PPP IPCP Receive Configuration ACK
05:02:41, 18 Mar. PPP IPCP Send Configuration Request
05:02:41, 18 Mar. PPP IPCP Receive Configuration NAK
05:02:41, 18 Mar. PPP IPCP Receive Configuration Reject
05:02:41, 18 Mar. PPP IPCP Send Configuration ACK
05:02:41, 18 Mar. PPP IPCP Receive Configuration Request
05:02:40, 18 Mar. PPP IPCP Send Configuration Request
05:02:40, 18 Mar. PPP CHAP Receive success : authentication successful
05:02:40, 18 Mar. PPP CHAP Receive Challenge
05:02:40, 18 Mar. PPP LCP Receive Configuration ACK
05:02:40, 18 Mar. PPP LCP Send Configuration ACK
05:02:39, 18 Mar. PPP LCP Receive Configuration Request
05:02:39, 18 Mar. PPP LCP Send Configuration Request
05:02:37, 18 Mar. PPP LCP Receive Configuration ACK
05:02:36, 18 Mar. PPP LCP Send Configuration Request
05:02:33, 18 Mar. DSL Link Up: Down Rate=3328Kbps, Up Rate=448Kbps; SNR Margin Down=6.3dB, Up=17.0dB
05:02:00, 18 Mar. PPP LCP Send Termination Request (User request)
05:01:57, 18 Mar. PPP LCP Send Termination Request (User request)
05:01:56, 18 Mar. DSL Link Down: duration was 87536 seconds
05:01:54, 18 Mar. PPP LCP Send Configuration Request
05:01:51, 18 Mar. PPP LCP Send Configuration Request
05:01:48, 18 Mar. PPP LCP Send Configuration Request
05:01:45, 18 Mar. PPP LCP Send Configuration Request
05:01:42, 18 Mar. PPP LCP Send Configuration Request
05:01:41, 18 Mar. WAN connection ATM disconnected
05:01:31, 18 Mar. PPP LCP Send Termination Request (User request)
05:01:28, 18 Mar. PPP LCP Send Termination Request (Peer not responding)
04:45:05, 18 Mar. NTP synchronization success
DiggerOfTrenches
Message 10 of 22
21:10:41, 12 Mar. NTP synchronization success
21:10:40, 12 Mar. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
21:10:40, 12 Mar. CWMP: Session start now, server: pbthdm.x.x.x, Event code:
21:10:40, 12 Mar. CWMP: Initializing transaction for event code 4 VALUE CHANGE
21:10:28, 12 Mar. NTP synchronization start
21:10:26, 12 Mar. WAN connection ATM connected
21:10:26, 12 Mar. PPP IPCP Receive Configuration ACK
21:10:25, 12 Mar. PPP IPCP Send Configuration Request
21:10:25, 12 Mar. PPP IPCP Receive Configuration NAK
21:10:25, 12 Mar. PPP IPCP Receive Configuration Reject
21:10:25, 12 Mar. PPP IPCP Send Configuration ACK
21:10:25, 12 Mar. PPP IPCP Receive Configuration Request
21:10:24, 12 Mar. PPP CHAP Receive success : authentication successful
21:10:24, 12 Mar. PPP CHAP Receive Challenge
21:10:24, 12 Mar. PPP LCP Send Configuration ACK
21:10:24, 12 Mar. PPP LCP Receive Configuration Request
21:10:21, 12 Mar. PPP LCP Receive Configuration ACK
21:10:21, 12 Mar. PPP LCP Send Configuration Request
21:10:18, 12 Mar. DSL Link Up: Down Rate=3104Kbps, Up Rate=448Kbps; SNR Margin Down=6.7dB, Up=17.0dB
21:09:51, 12 Mar. PPP LCP Send Termination Request (User request)
21:09:48, 12 Mar. PPP LCP Send Termination Request (User request)
21:09:48, 12 Mar. DSL Link Down: duration was 2716 seconds
21:09:47, 12 Mar. PPP LCP Send Configuration Request
21:09:46, 12 Mar. WAN connection ATM disconnected
21:09:37, 12 Mar. PPP LCP Send Termination Request (User request)
21:09:34, 12 Mar. PPP LCP Send Termination Request (Peer not responding)
20:46:08, 12 Mar. admin login success from 192.168.1.190
20:25:43, 12 Mar. CWMP: HDM socket closed successfully.
