Message 1 of 7
Phone Line Micro Filter
Hello,
I recently tested my phone line for a fault, which was the ADSL micro filter, and on the support page, it summarises that BT Broadband members can receive a ADSL micro filter for free.
Where would I be able to order this, as the only place I can find them is on the BT Shop page, but I need to pay for it there.
6 REPLIES 6
Message 2 of 7
Re: Phone Line Micro Filter
Try phoning CS on 150
Message 3 of 7
Hi @LT1 and welcome to our community.
Thanks for posting about the micro filter. Can you just clarify that it was the filter that was causing the landline issue? has that now been sorted? How long have you had the filter? If it's faulty you could try calling 150 as posted by @imjolly or you can pick one up quite cheaply at a number of retailers.
Cheers
David
Message 4 of 7
Hi @DavidM ,
When testing the line last night, I had heard crackling on the quiet line, so I removed the phone from the ADSL filter, and plugged it into the master.  Once I did that, the crackling seems to have stopped.
I have had the filter for about 1-3 years now, and have just ordered another one, which is due to arrive today.
I will let you know later today if the issue has been fully resolved.
Message 5 of 7
Hi @LT1 ,
Thanks for getting back. Let me know how  it goes with the new filter.
Cheers
David
Message 6 of 7
Back again @DavidM ,
It’s been around an hour after inserting the new ADSL filter, and everything seems to be perfect so far.  No noise coming from the phone line and the broadband has improved as well - no jittering or disconnecting.
Message 7 of 7
Sounds like you found the cure @LT1 . Thanks for getting back and letting me know.
Cheers
David
