galabonnyboy
Message 1 of 4
Ping been bad for about two months
Hey I have had BT broadband for about three years. But recently my ping has dramatacly increased I think there maybe a fault on my line?
http://www.pingtest.net/result/97085325.png
Any idea on what I could do? I am on the master socket and have been since I got broadband. There is no reason my ping should be this high. It used to be 25
Spoiler
ADSL Line Status
Connection information
Line state:Connected
Connection time:0 day, 00:04:30
Downstream:8,128 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):6.6 dB / 22.0 dB
Line attenuation (Down/Up):23.0 dB / 11.5 dB
Output power (Down/Up):19.9 dBm / 11.9 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):1 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):6 / 0
Error Seconds (Local/Remote):0 / 0
3 REPLIES 3
Message 2 of 4
Re: Ping been bad for about two months
can you run a traceroute using windows command prompt to bbc.co.uk and post bac the resolts please
galabonnyboy
Message 3 of 4
Trace to bbc.co.uk
Spoiler
Tracing route to bbc.co.uk [212.58.246.104]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms BTHomeHub.home [192.168.1.254]
2 12 ms 13 ms 12 ms esr19.edinburgh8.broadband.bt.net [213.1.130.142
3 17 ms 21 ms 13 ms 213.1.130.125
4 21 ms 21 ms 22 ms 213.1.69.154
5 21 ms 20 ms 21 ms 31.55.165.49
6 21 ms 20 ms 24 ms 31.55.165.107
7 27 ms 40 ms 28 ms 109.159.250.52
8 33 ms 31 ms 32 ms core2-te0-13-0-14.ilford.ukcore.bt.net [109.159.
250.46]
9 31 ms 30 ms 29 ms peer2-xe3-1-1.telehouse.ukcore.bt.net [109.159.2
54.233]
10 32 ms 32 ms 31 ms 194.74.65.42
11 * * * Request timed out.
12 33 ms 30 ms 29 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
13 35 ms 32 ms 33 ms 132.185.255.165
14 31 ms 31 ms 31 ms fmt-vip133.cwwtf.bbc.co.uk [212.58.246.104]
Trace complete.
Ping test to bbc.co.uk
Spoiler
C:\Users\Gary>ping bbc.co.uk
Pinging bbc.co.uk [212.58.246.104] with 32 bytes of data&colon;
Reply from 212.58.246.104: bytes=32 time=30ms TTL=51
Reply from 212.58.246.104: bytes=32 time=31ms TTL=51
Ping statistics for 212.58.246.104:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 30ms, Maximum = 31ms, Average = 30ms
Everything seems good for now, but it gets really bad at night sometimes for hours on end. Ill see if anything happens tonight then do another trace.
Message 4 of 4
ok thanks there is always some one around to help
