Blaikie
Message 11 of 18
Re: Ping increase/interleaved & ADSL2 enquiry
Yes, but similar reports? What could it be?
Message 12 of 18
Did you mark as solved as only you and mod can do it. Just go To message 9 and then options on right and unmark solved
Blaikie
Message 13 of 18
I didn't mark it but I unmarked it now.
Blaikie
Message 14 of 18
Hello again,
I've been monitoring my connection for almost 2 days now without any drops despite what I've mentioned previously.
I'd like to request that interleaving be changed to fast and I would also like to push for an upgrade to ADSL2+ as I'm almost certain my line is stable and good enough for it considering the decent nouse margin, no errors and stability.
Many thanks,
Robert
Message 15 of 18
would it not be better to get mods to change latency to fast and see if you line can handle that before going to a more aggressive system on noise with a line that has beed dropping out in the recent past?
Blaikie
Message 16 of 18
I've had the line on fast before but I can certainly just try that for now, sure.
Message 17 of 18
the mods will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
Moderator
Moderator
Message 18 of 18
Hi Blaikie,
I can help you from here.
I'd suggest removing interleaving first of all to see how the line is performing and then we can do the upgrade at that stage.  Click on my username and under the "about me" section of my profile you'll see the link to get in touch with us.
All the best,
Robbie
