lordbanded
Message 1 of 5
Please help! Banded profile for too long!
I had a fault on my line which was fixed by an engineer. I had many drops before the fix which caused my line to gain noise and put me on a banded profile. The engineer said i will get my speed back after some time. I waited over 14 days and decided to restart the router and it still did not release me from being banded. I have waited another 8 days and i have a picture to show the noise margin and connection up time.
As you can see, my maximum data rate should be 24420, i did have this speed before the fault and i would like it back!! Please help, thank you!
4 REPLIES 4
NeilO
Moderator
Moderator
Message 2 of 5
Re: Please help! Banded profile for too long!
@lordbanded Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll be happy to help. You can find the link by clicking on my username.
Neil
JohnC2
Moderator
Moderator
Message 3 of 5
Hi @lordbanded Thanks for sending over your details. I've ordered a profile reset this morning and this should complete in the next 24hrs. Please check on your connection later and post back to let me know how it is performing.
Cheers
John
lordbanded
Message 4 of 5
Hello @JohnC2! It appears to have worked!
My maximum achievable data rate has dropped slightly but I can't complain really, 22000 is better than 14000!!
Thank you very much for your help!
NeilO
Moderator
Moderator
Message 5 of 5
@lordbanded Brilliant I've let @JohnC2 know thats sorted now Smiley Very Happy
