Guru
Guru
Message 11 of 43
Re: Possible Fault
Just an update on the stats.
SNR has decreased and errors have ,unsurprisingly, increase with a connection time of 1hour and 52 minutes, even without using the landline phone.
Also tested with the phone and:
The snr hasn't dropped that much when using the landline but the errors have started increase already.
**All below stats are from homehub when connected to ADSL v1 Master Socket**
Before using landline phone:
Line state:Connected
Connection time:0 days, 01:50:08
Downstream:1.688 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):3.6 dB / 10.0 dB
Line attenuation (Down/Up):66.2 dB / 31.5 dB
Output power (Down/Up):17.0 dBm / 12.6 dBm
FEC Events (Down/Up):249152 / 260
CRC Events (Down/Up):1134 / 32
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):4118 / 84
Error Seconds (Local/Remote):47 / 36
 When using landline phone:
Connection time:0 days, 01:52:46
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):2.9 dB / 10.0 dB
FEC Events (Down/Up):251229 / 262
Best Regards,
jac_95
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Guru
Message 12 of 43
Re: Possible Fault
I'll bet 10 bob that takes a dive tonight .... around 7- 8 ish.    😉
Guru
Guru
Message 13 of 43
Re: Possible Fault
You could be right RogerB, we'll see if it drops tonight.
Here's what it's like so far: - When on the landline phone snr currently drops to around 2.3dB to 2.5dB
Connection time:0 days, 05:51:06
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):3.0 dB / 10.0 dB
FEC Events (Down/Up):284226 / 894
CRC Events (Down/Up):1144 / 70
HEC Events (Down/Up):4172 / 110
Error Seconds (Local/Remote):55 / 62
Cheers
Try a Search
Guru
Message 14 of 43
Re: Possible Fault
I'd be surprised if it didn't .... 🙂
Either that ... or the bitstream grind ...   😞
2/1 on, ... for a drop.
Even money for the bitstream grind.  😉
(but I won't take pleasure in knowing that you'll get either jac )    😉
Message 15 of 43
Re: Possible Fault
as long as not many phone calls I go for even money betSmiley Wink
Guru
Guru
Message 16 of 43
Re: Possible Fault
Looks like it's decided to hang on Smiley Very Happy
Here's the stats:
Connection time:0 days, 09:34:09
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):4.2 dB / 10.0 dB
FEC Events (Down/Up):311252 / 1228
CRC Events (Down/Up):1164 / 119
HEC Events (Down/Up):4226 / 146
Error Seconds (Local/Remote):67 / 87
Best regards,
jac_95
Try a Search
Guru
Message 17 of 43
Re: Possible Fault
Not only has it hung on ... it's upped the noise margin to boot.
That's good news jac .... all you need now is your line problem sorting.
Is browsing good or bad ....?
Guru
Guru
Message 18 of 43
Re: Possible Fault
The Internet seems fine with a BTw speedtest of 1.45mb DL and 0.3UL
Currently the landline phone is being used so here's the stats:
Connection time:0 days, 09:53:08
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):3.5 dB / 10.0 dB
FEC Events (Down/Up):317632 / 1234
seems to be behaving itself tonight Smiley Very Happy
Cheers
Try a Search
Guru
Guru
Message 19 of 43
Re: Possible Fault
Hi all,
Just an update on the line statistics. It seems to be behaving itself at the moment and has recently resynced with a 1.75mb syncrate which I think is very good for a 66+dB line.
Connection time:0 days, 01:46:51
Downstream:1.75 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.2 dB / 11.0 dB
Output power (Down/Up):16.9 dBm / 12.6 dBm
FEC Events (Down/Up):594 / 243
CRC Events (Down/Up):1 / 10
HEC Events (Down/Up):0 / 5
Error Seconds (Local/Remote):1 / 6
Cheers
Try a Search
Guru
Guru
Message 20 of 43
Re: Possible Fault
Hi all,
Haha thought it had stopped doing this as for the last few days it's been at 1.6mb, but since this morning it dropped out as the phone rang and sync rate became 832kbps.
And now the errors build up and snr decreases when we use the landline phone.
Think time to ring BT and see what they can do, but the line will probably pretend that all is alright Smiley Very Happy
All the below tests was setup using the Openreach Adsl v1 Filtered Master Socket
Before using the landline phone:
Connection time:0 days, 00:34:15
Downstream:832 Kbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):10.2 dB / 11.0 dB
Line attenuation (Down/Up):66.1 dB / 31.5 dB
Output power (Down/Up):16.8 dBm / 12.6 dBm
FEC Events (Down/Up):633 / 43
HEC Events (Down/Up):4 / 0
Error Seconds (Local/Remote):434 / 322
While using landline phone
Connection time:0 days, 00:36:47
Downstream:832 Kbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.3 dB / 11.0 dB
FEC Events (Down/Up):96454 / 91
CRC Events (Down/Up):921 / 42
HEC Events (Down/Up):5470 / 88
Error Seconds (Local/Remote):459 / 337
After using the landline phone
Connection time:0 days, 00:39:05
Downstream:832 Kbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
FEC Events (Down/Up):99573 / 92
Thanks agian,
Cheers
Try a Search
