Guru
Guru
Message 41 of 43
Re: Possible Fault
Just a stats update.
Speedtest:
Traceroute to bbc.co.uk:
traceroute to bbc.co.uk (212.58.241.131), 64 hops max, 72 byte packets
 1  api (192.168.1.254)  2.181 ms  1.569 ms  1.631 ms
 2  217.32.141.34 (217.32.141.34)  23.318 ms  19.697 ms  25.089 ms
 3  217.32.141.78 (217.32.141.78)  156.072 ms  167.095 ms  174.107 ms
 4  217.41.216.202 (217.41.216.202)  162.388 ms  136.939 ms  147.788 ms
 5  31.55.164.227 (31.55.164.227)  196.520 ms *  164.607 ms
 6  31.55.164.109 (31.55.164.109)  132.059 ms  162.982 ms  159.296 ms
 7  acc2-10gige-0-7-0-5.bm.21cn-ipp.bt.net (109.159.248.206)  161.469 ms  155.301 ms  155.720 ms
 8  core2-te0-13-0-4.ealing.ukcore.bt.net (109.159.248.138)  148.376 ms  163.221 ms  163.981 ms
 9  peer2-xe3-2-1.telehouse.ukcore.bt.net (109.159.254.225)  164.525 ms  165.101 ms  170.609 ms
10  194.74.65.42 (194.74.65.42)  172.301 ms  171.382 ms  187.893 ms
11  * * *
12  ae1.er01.rbsov.bbc.co.uk (132.185.254.46)  208.296 ms  180.687 ms  188.474 ms
13  132.185.255.60 (132.185.255.60)  180.277 ms  190.362 ms  181.391 ms
14  212.58.241.131 (212.58.241.131)  173.477 ms  179.747 ms  172.779 ms
Adsl Stats:
Line state:Connected
Connection time:6 days, 20:44:08
Downstream:1.625 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):4.2 dB / 10.0 dB
Line attenuation (Down/Up):65.6 dB / 31.5 dB
Output power (Down/Up):16.7 dBm / 12.5 dBm
FEC Events (Down/Up):0 / 951
CRC Events (Down/Up):3471878 / 6657
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):546911 / 190
Error Seconds (Local/Remote):305972 / 5290
cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Guru
Message 42 of 43
Re: Possible Fault
jac .....
Forget the reset tonight, you need to wait to get the IP profile up first.
It's at a low ebb.  Wait for it to come up .... then reset if the noise margin is lower than 3db at night.   😉
Guru
Guru
Message 43 of 43
Re: Possible Fault
Hi all
Just wanted to update this thread.
It's now been about 24 Days in the Openreach VDSL Master socket.
The Homehub3 has also updated to Software version 4.7.5.1.83.8.94.1.11
For the last week or so I have been enjoying a good sync rate of 1.875 Mbps. Hoping it will last Smiley Very Happy
Here are the stats:
Connection time:5 days, 11:02:28
Downstream:1.875 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Interleaved
Noise margin (Down/Up):5.3 dB / 10.0 dB
Line attenuation (Down/Up):66.0 dB / 31.5 dB
Output power (Down/Up):17.1 dBm / 12.4 dBm
FEC Events (Down/Up):298125 / 3885
CRC Events (Down/Up):3804 / 703
HEC Events (Down/Up):18561 / 562
Error Seconds (Local/Remote):1729 / 510
Speedtest:
Cheers,
And thanks for all the help Smiley Happy
Blwyddyn Newydd Dda, Happy New Year!
Kind regards.
Try a Search
