Message 1 of 3
Power Extension Cable for Smarthub 2
I'm looking for dc extension cable up to 10m for BT SH2. I've tried a couple but turns out the SH2 has a non standard connector. I'm still not sure if it's 5.5mm x 3mm, 3.1mm or what. Can anyone confirm the precise one and where I can get one. Or maybe an adapter for a 5.5mm x 2.1mm cable which seem readily available?
2 REPLIES 2
Message 2 of 3
Re: Power Extension Cable for Smarthub 2
It is 3.0 X 5.5 and you will find a plug at CP Farnell's, if memory serves, but good luck with finding a socket or a pre-made up lead.
10m is a very long distance for a low voltage extension anyway.  A mains lead might be better.
Message 3 of 3
