kelvinbridge
Message 11 of 15
Re: Problems with Broadband speed and connection despite 2 visits by engineer
Could you explain how ''he'' as you advised him >>  '' you can maintain a stable connection for 3/5 days ''
maintain a stable connection, if his connection is dropping , is he allowed to climb bt poles to carry out repairs ?
Andrews1
Message 12 of 15
John
A miraculous thing has happened
Since the router reset itself last  time - speeds have gone complelely up.
Download speedachieved during the test was - 1.46 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :1.79 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 1.5 Mbps
Out of interests sake I am guessing that the exchange did the last automatic router reset.
And as you have explained in other posts it reset the IP profile etc..
Andrew
Message 13 of 15
yes it looks as if the DLM has reset your line following a period of stable connection pleased all appears back to normal now
Andrews1
Message 14 of 15
John
I really appreciate what you do.
We have spent ages rebooting the router etc
Without understanding that this is the worst thing one can do.
If I hadn't connected here and 'listened' we could have been in a permanent loop!
Best
Andrew
Message 15 of 15
If you need any further help any time there is always someone around to help
