jonnygordon77
Message 1 of 10
Re: Can I upgrade from ADSL Max to ADSL2+?
Would it be possible to migrate my account to ADSL2+? I've been through the checker and it appears to be available to us. Thanks.
9 REPLIES 9
jonnygordon77
Message 2 of 10
The results from the checker are shown below, thanks:
jonnygordon77
Message 3 of 10
Can anyone help or suggest someone I can contact about this? Thanks.
Message 4 of 10
Have you contacted sales? You can usually have the service switched by agreeing to a new contract.
jonnygordon77
Message 5 of 10
Hi, thanks. All the posts so far requesting this have been carried out via the forum. I'm enquiring this way because this apparently saves having to negotiate a new contract. I don't think this kind of change really justifies a new contract. Cheers, Jonny
Message 6 of 10
even if moved via the forum it will involve a new contract
jonnygordon77
Message 7 of 10
OK. If anyone can do that I'd appreciate it. Thanks.
Message 8 of 10
Phone customer options 0800 800 030 they should be able to help you
jonnygordon77
Message 9 of 10
I'm in touch with one of the moderators so hopefully I'll get it sorted from there. Cheers.
Message 10 of 10
As the mods work by personal invite only how did you contact them as they do not use private messages as they cannot be properly tracked
