Message 31 of 46
Re: Can I upgrade from ADSL Max to ADSL2+?
You need to go into advanced settings, troubleshooting, then helpdesk I believe.
I can almost guarantee it's G.992.1 though with those connection rates.
ScottyM45
Message 32 of 46
Webby, as you say the router is reporting G.992.1
So BTw accepted the order to transfer me, which was confirmed by a notice on adsl checker and also a temporary outage on the day the switch was to be made. Why am I still stuck at the lower speeds?
1. Product name: BT Home Hub
2. Serial number: +068340+NQ62526451
3. Firmware version: Software version 4.7.5.1.83.8.130.1.32 (Type A) Last updated 21/10/16
4. Board version: BT Hub 4A
5. ADSL uptime: 0 days, 09:57:20
6. Bandwidth: 448 / 8128
7. Data sent/received: 30.9 MB / 883.4 MB
8. Broadband username: bthomehub@btbroadband.com
9. BT Wi-fi: Yes
10. 2.4 GHz Wireless network/SSID: BTHub4-ZKTQ
11. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4 GHz Wireless security: WPA and WPA2
13. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID: BTHub4-ZKTQ
15. 5 GHz Wireless connections: Enabled (802.11 a/n (up to 300 Mb/s))
16. 5 GHz Wireless security: WPA2
17. 5 GHz Wireless channel: Automatic (Smart Wireless)
18. Firewall: Default
19. MAC Address: 40:c7:29:00:74:82
20. VPI/VCI: 0 / 38
21. Modulation: G.992.1 Annex A
22. Latency type: Fast
23. Software variant: -
24. Boot loader: -
Message 33 of 46
As I said, this needs moderator investigation.
ScottyM45
Message 34 of 46
The "contact us" for the mod is still available for me to click on, shall I contact them or do I need to wait until they reply here?
Moderator
Moderator
Message 35 of 46
Hi @ScottyM45 Sorry this is still not sorted. You would need to send us your details again you can use the link that you already have to send them in.
Thanks.
John
ScottyM45
Message 36 of 46
Thanks @JohnC2 I have sent the query in. Hope you guys are able to help me out again.
Moderator
Moderator
Message 37 of 46
Hi @ScottyM45,
Thanks for sending over the details. I tried calling today, sorry I missed you. I've managed to get the order placed for you. It'll complete by midnight on Monday so can your try checking the connection on Tuesday and let me know if you see any change?
Cheers
David
ScottyM45
Message 38 of 46
Hi @DavidM sorry I missed your call, poor signal where I was!
Thanks for having a look into my issue and I shall let you know on here how my connection is next week.
ScottyM45
Message 39 of 46
@DavidM
So I have checked my connection, seems my router resynced yesterday at some point. Sync speed is a shade over 18 down  which is what I expected from my line performance. However, download speed is very slow, I presume this is part of the training period?
Test taken this morning at around 6am. I will check again this evening
Message 40 of 46
Wired or wireless?
