Message 41 of 106
Re: Download times abysmal
can you run btspeedtester and when first test completes then run diagnostic test and post the results
btspeedtester
bullshot
Message 42 of 106
Download 8.37 upload 0.84 Ping latency 35.63 that was info for speed test this is info for
Broadband Diagnostic Test
Download speed achieved during test was 8.37!, for your connection the acceptable range of speeds is 4 - 21 Mbps
IP profile for your line is 8.58
Lots of other about upload and it says unable to identify any performance problem with your service at this time it is probably internet traffic
But have never had it this slow in years......had 16 during the day and sometimes 18
bullshot
Message 43 of 106
is that the info you asked for...using macbook now, ipad typing too slow
bullshot
Message 44 of 106
BTW ust had chat to wife of techie bloke next door and they switched from BT and are with Talk Talk and she hs no idea if they have infnity, but does not think so as she says the internet goes very slowly whe daughter is using her ipad to chat to friends
Message 45 of 106
which version of the hub are you using?
bullshot
Message 46 of 106
home hub 3
Message 47 of 106
lets see if you can get the stats from the hh3  here are the instructions similar to going to wireless just a different heading
BT HomeHub 3
From http://192.168.1.254
Settings >
Advanced Settings >
Broadband >
Connection >
Click "Show Details" Button at the bottom
You can also try the direct link
http://192.168.1.254/index.cgi?active_page=9116
Note 1. If this is the 1st time you have been to the Hub manager you will have to change & set your admin password.
bullshot
Message 48 of 106
had this problem last year itwas doing this all the time , and finally lost internet altogther...took my home hub 2 to friends house and it would not work there, BT sent me this Home hub 3 and problems stopped instantly and speed was great again, never dropped off at all until recently and been resetting router 5 or 6 times a day now for weeks...getting really fed up of it, but she says router is fine
bullshot
Message 49 of 106
Internet Connection Configuration
Connection Information
Connection time:0 days, 03:23:19
Data Transmitted/Received (GB):0.0 / 0.4
Broadband username:bthomehub@btbroadband.com
Password:Not configured
TCP/IP settings
Broadband network IP address:109.151.145.230
Default gateway:213.120.155.230
Primary DNS:213.120.234.54
Secondary DNS:194.72.0.114
bullshot
Message 50 of 106
is that what you wanted  or have i done it wrong
