ms98tjc
Message 1 of 6
Re: Maximum data rate
I appear to have a very similar issue to the one described in this thread, could you be of assistance?
DSL details below. I was having regular drop outs and now it appears to be limiting my connection speed. I have had multiple online chats and have an engineer coming next week, but wondered if you can help?
TCM(Trellis Coded Modulation)SNR MarginLine AttenuationPath ModeInterleave DepthData RateMax RatePowerINPINP-SHINEINP-REINCRC
On
On
27.6 dB
25.6 dB
30.8 dB
12.1 dB
Interleaved
FastPath
160
1
2272 kbps
444 kbps
14136 kbps
1124 kbps
0.0 dbm
11.3 dbm
2.3 symbols
0.0 symbols
73
Message 2 of 6
All your connection problems have resulted in you ending up in a banded profile. There is no point in doing anything until engineer visit and hopefully fixes your connection stability problem. Once fixed engineer may reset noise margin and speed will return
Moderator
Moderator
Message 3 of 6
Hi @ms98tjc,
How did things go with the engineer?
If you're still experiencing issues with your connection, please post back.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
ms98tjc
Message 4 of 6
@PaddyB
He changed the interleave depth to 64 which has increased the speed, but I am still getting CRC errors and my router still reports the DSL line is unstable. It seems to drop at least once every 24 hours. He said the line showed no fault. It is the same answer I got last time a few months back. Sorted it for a while but then it will probably slow down again. I also don't really see it as a solution, as it has done nothing to solve the underlying problem, it just masks the issue.
Tom
ms98tjc
Message 5 of 6
Still having regular dropouts. Though almost managed 48 hours without one! Trying to see if I can get fibre enabled at my cabinet as it is in other ones in my town, but ends at the end of my street!
Message 6 of 6
enter your phone number and post results  https://www.btwholesale.com/includes/adsl/main.html
remember delete number
