phildalegend
Message 21 of 55
Re: Poor Broadband speed
but the master socket is already in use by my phone
phildalegend
Message 22 of 55
and i have already said the engineer tested the master socket if you read my posts earlier
Message 23 of 55
the master socket still has your internal wiring connected which may cause noise problems whereas the test socket eliminates all internal wiring test socket.jpg
phildalegend
Message 24 of 55
that is what the engineer tested -_- i think he would know more than you.
Message 25 of 55
that's your choice so up to you how you progress
if you have a noisy line then report a fault
phone faults
phildalegend
Message 26 of 55
Ok I have checked every extension to see if they have ADSL filters and they all do but still getting a lot of noise, also done the quiet line test and is very quiet, could it be a faulty router?
Sorry for being a bit arrogant, just frustrating having constant problem >_<
Message 27 of 55
could you please connect your hub to the test socket and post back the ADSL stats to compare against your originals already posted this will also eliminate any internal wiring problems
phildalegend
Message 28 of 55
An engineer has checked the test socket several times over the last 3 months and the master socket is in constant use by my phone
Message 29 of 55
you can still use your phone while connected to the test socket
phildalegend
Message 30 of 55
but whenever i use the master socket (in an inconvenient cupboard) i can never connect to the router
