Message 11 of 17
Re: Slow speed after service loss
Hi There are no passwords to change and checking at the test socket is the basic check that will stop you having to pay for an engineer as visit as it eliminates your extensions and equipment as Openreach are responsible up to the test socket all extensions however are your responsibility Also changing providers is unlikely to resolve the problem as all providers use the same Openreach connections the only exception is Virgin cable
Are you connecting your computer to the hub using a wired or wireless connection
jilly
Message 12 of 17
Virgin is cable. What about BT infinity?
Message 13 of 17
infinity is fibre from the exchange to your street cabinet and then the existing copper wires from street cabinet to your home - some now have fibre from cabinet to home but they are in minority
jilly
Message 14 of 17
I connect by wireless.  when I tried to do the other test (not adls) I was aked to change hub manager password.
jilly
Message 15 of 17
Will infinity cure the problem I have at the moment
Message 16 of 17
it would help if as others have asked if you connect the hub via a filter direct to the test socket.  this is your best connection and is direct to the exchange
peteratsrinagar
Message 17 of 17
Hi,
 I have similar problems. I have contacted Bt several times now but they do not respond. It appears to me, as with life in general today, it's take the money and run....screw the customer. All I can say is that since SF B\B doesn't work properly then it should not have been rolled out in the first place. I have asked for a refund of this months B\B fees and line rental....but if it's a refund for poor service....BT goes deaf, dumb and blind!
