What-a-joke
Newbie
Message 1 of 2
Re: Very slow broadband speed since 26th Jan 2014. Any known reason?
I have the same problem, just gaet the same old answers that it is being monitored. Unreturned calls and no help whatsoever.
1 REPLY 1
Message 2 of 2
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
I moved your post to start your own thread to avoid confusion with the original poster of the previous thread
if you want help then in order for the forum members to help please can you post the adsl stats from your router you may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or if HH4/5 then go to troubleshooting then logs and you are looking for 2 line together when hub last connected to internet and they will show your connection speed and noise margin or if netgear enter 192.168.0.1). Then run  btspeedtester  (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
