hjj5578
Message 1 of 29
Really bad broadband
Can someone help me? I have had BT broadband for about 2 to 3 months now and it has never really worked - speeds of around 4 to 5 mbps. Previous complaint was closed though I asked for it not to be as issue wasn't solved and speednow down to 0.5mbps and yet another engineer coming out - this is either 3 or 4. I need this connection working to be able to work from home properly and I am just going round in circles. Have changed filters etc etc. Is there any hope anyone can offer me on the chances of getting this sorted??
28 REPLIES 28
Message 2 of 29
Re: Really bad broadband
Welcome to this user forum. @hjj5578
Do you have normal ADSL broadband, or are you on superfast "fibre"?
hjj5578
Message 3 of 29
Normal ADSL broadband over a copper line I think
hjj5578
Message 4 of 29
Message 5 of 29
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
hjj5578
Message 6 of 29
There is a pretty constant hiss on the line
Message 7 of 29
It should be quiet.
What does your master phone socket look like?
Master socket with one socket
Or
Master socket with two sockets
hjj5578
Message 8 of 29
It is one of the top ones - there is no test socket
Message 9 of 29
The only one without a test socket is the top right one, is that the one you have?
Do you have any other phone sockets or phone extension wiring?
hjj5578
Message 10 of 29
Sorry - it is the second one from left on top row - didn't realise it had one.
