Message 11 of 29
Re: Really bad broadband
@hjj5578 wrote:
Sorry - it is the second one from left on top row - didn't realise it had one.
Yest it does, its  one of the new one.
Please connect things up as shown below, and see if you still get the noise on the phone.
hjj5578
Message 12 of 29
Thanks - done that and still have a constant hiss.
Message 13 of 29
Are there any other phone sockets or phone extension wiring in the house?
hjj5578
Message 14 of 29
No - none at all. Really appreciate your help
Message 15 of 29
Thanks for that info.
What speed were you told to expect on your connection?
Which BT home hub are you using?
If you use this form, it should tell you your expected ADSL speed range.
Please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
hjj5578
Message 16 of 29
Sorry but not sure how I attach the download to here. When I ordered it they said speed would be between 10 and 14 mbps with minimum of 5.88. Never other than for a few days had the minimum. I have a home hub 2
Message 17 of 29
You can upload a picture using the camera icon.
I assume you mean you have the new smart hub 2, and not the old obsolete  home hub 2?
Can you please post the connection information?
Open a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log’
hjj5578
Message 18 of 29
Thanks - I am out at the moment but will when I get home.
Message 19 of 29
That`s fine, post whenever you can, and someone should be able to help.
I assume that its the connection speed you have problems with, and not the actual download speed?
Download speed needs to be measured using an Ethernet connected device, as wireless will give variable results.
hjj5578
Message 20 of 29
Just to let you know the reason I haven't posted the results is because although the hub shows a blue light the connection is so bad it won't even connect to the website to get the information. I will post it should I ever get a good enough connection.
