SimonKB
Message 1 of 3
Reduced speed.
Hello. Can anyone tell me what is happening here please. Speed dropped from 13 Mbps to 5.6 Mbps about ten days ago and has not improved since. No other changes to previous set up so am slightly confused. Thank you in anticipation for any comments.
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 5 days, 17:56:00
Downstream: 5.617 Mbps
Upstream: 1.125 Mbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.3 Annex A
Latency type: Fast
Noise margin (Down/Up): 6.0 dB / 6.1 dB
Line attenuation (Down/Up): 20.5 dB / 12.4 dB
Output power (Down/Up): 17.1 dBm / 12.0 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 1429 / 1318
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 4874 / 1062
Error Seconds (Local/Remote): 984 / 690
2 REPLIES 2
Message 2 of 3
Re: Reduced speed.
are you conencted to the test socket and if not can you conenct to test socket and post new stats
Darren_G
Message 3 of 3
Re: Reduced speed.
Still faster than mine......but most people are! Man Mad
