jaydog69
Message 1 of 3
Returning a Hub?
Just been sent a replacement hub as my old one kept dropping connections.
BT told me on chat that I can keep the old one, but there's a leaflet in the new box saying BT may charge me if I don't return the old one?
I've had the old one for about 14 months. Do I have to return the old one?
2 REPLIES 2
Message 2 of 3
Re: Returning a Hub?
If you have had old hub for that long I would just hold on to it as I don't think you should get charged after fixed term 12 month contract finished
Distinguished Guru
Message 3 of 3
If it's a warranty replacement, then the T&Cs say that you must return the faulty one within 30 days or you may be charged. See http://www.productsandservices.bt.com/products/static/terms/post3rdjuly2016voiceandbroadband.html paragraph 16.
If you are in contract, then the Home Hub is considered in warranty, even if it's over 12 months old.
Given that the old one was on the blink anyway, I suggest it may be easier just to send the old one back, rather than having to argue about an unexpected bill down the line.
