Message 11 of 12
Re: Rubbish connection, especially evenings!
If using a hub 4 locate these lines located in the hub logs
Lines should look like this you can find them in the WAN dropdown
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Message 12 of 12
the quiet line test 17070 option 2 should be as it says silent
wireless is never the most reliable way of connecting as it is subject to too much external interference also no ISP will guarantee wireless speeds can you also post the results of the further diagnostic part of the speedtest
This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Upgrading your hub will achieve nothing
