JU73
Message 1 of 21
SLOW SPEEDS- NEW BUILD PROPERTY!!
Hello
We moved into a brand new property 2 years ago and have had nothing but slow, intermittent, and altogether useless speeds since moving in. We were orignally with Sky broadband then changed to Vodafone and now we have joined BT hoping that they may soon help?? Sky and Vodafone both sent out BT engineers regularly to test the broadband and every time they couldnt find a fault. One BT Engineer did advise me that The R.E.I.N team have apparantly been investigating the problems on our esate and they say it is an electrical fault with the solar panels on our estate.
I need to know how I can contact the REIN team who can confirm this and obtain a report from them so that i can complain to the housebuilder/solar panel company and see if the interference can be rectified. We have no Virgin Cable, nor Fibre and Im quite frankly dismayed that in 2017 i am only achieveing speeds of under 1, we are not in the middle on nowehere either we are very close to exsisting residentail areas and shopping centres.
Can anyone help please ??
20 REPLIES 20
Message 2 of 21
Re: SLOW SPEEDS- NEW BUILD PROPERTY!!
Welcome to this user forum.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Which BT home hub are you using?
JU73
Message 3 of 21
Hi its a BTHub4-28ZH
 WBC ADSL 2+     Up to 3
JU73
Message 4 of 21
WBC ADSL 2 + Up to 3    Downstream Line and 2.5 to 6.5 Downstream Range
ADSL Max Up to 3 Downstream Line and 2 to 5.5 Downstream range
WBC Fixed rate 1
Fixed rate 1
Bridge Tap U
VRI N
NTEFaceplate N
sorry i couldnt copy the actual results so had to type manually
Message 5 of 21
Please could you provide the actual connection speeds?
https://community.bt.com/t5/Announcements-Guides-Community/Broadband-Top-Tips-to-get-help-on-the-for...
There is a Youtube video link on that page.
JU73
Message 6 of 21
download speed 0.55mbps
upload speed 0.23mbps
ping latency 88.50ms
Message 7 of 21
What exchange and cabinet number?
JU73
Message 8 of 21
Ingrebourne
Cabinet 50
Message 9 of 21
Have you tried putting your number into the Openreach when and where site? If so, what stage is the cabinet showing as?
JU73
Message 10 of 21
Says fibre enabled for that cabinet but on the left it says we don't have plans for your area yet so I don't know tbh
