a_e
Message 11 of 56
Re: SNR fluctuation and banded after line upgrade
Quiet line test is still clear with no obvious line noise. Both router and phone are still connected to the filter in the test socket.
Message 12 of 56
as you have 5+ days stable connection I would wait just now and as long as line stable then you should get out of the banded profile with noise margin dropping and speed increasing
a_e
Message 13 of 56
Unfortunately nothing appears to have changed in regards to the banded profile and SNRM!
I’m now at 11+ days stable connection which I hoped would have been enough for the DLM to record a stable line. I’ve routinely been checking the quiet line test, but it’s still clear!
Is there anything that could potentially be stopping the speed from recovering?
Over the weekend I noticed some strange patterns to the SNR which I don't know if could be REIN. But realistically, would electrical interference stop the banding from being released?
Here are my current stats:
Line Rate - Upstream (Kbps)732
Line Rate - Downstream (Kbps)2270
Connection Time11 Day(s) 19:14:22
xDSL
Mode
ADSL_2
Traffic Type
ATM
Status
Up
Link Power State
L0
Downstream
Upstream
Line Coding (Trellis)
On
On
SNR Margin (dB)
12.3
9.0
Attenuation (dB)
36.0
21.7
Output Power (dBm)
19.0
12.2
Attainable Rate (Kbps)
6152
1164
Rate (Kbps)
2270
732
K (number of bytes in DMT frame)
0
0
R (number of check bytes in RS code word)
0
0
S (RS code word size in DMT frame)
0
0
D (interleaver depth)
160
8
Delay (msec)
7
5
INP (DMT symbol)
6.00
2.00
Super Frames
90009749
50390006
Super Frame Errors
1220
849
RS Words
1207619957
3690680
RS Correctable Errors
2822570
33458
RS Uncorrectable Errors
34564
0
HEC Errors
5661
1081
OCD Errors
94
0
LCD Errors
94
0
Total Cells
1161650183
1759109817
Data Cells
1580425778
142451961
Bit Errors
0
135862
Total ES
532
406
Total SES
2
5
Total UAS
23
23
Some graphs from the weekend to illustrate the strange SNRM:
04/02
05/02
If anyone has any suggestions, I'd be very grateful!
Message 14 of 56
as you have 11 days stable connection try 1 reset NOT factory reset and see if that gets speed back  if not repost stats and will see if mods will get you out of banding
a_e
Message 15 of 56
@imjolly
Is it best to restart the router (keeping current settings) in the routers control interface? Not by turning it off at the wall?
Will the DLM think there is a problem if I restart?
Message 16 of 56
you want it to see a restart to see if it will release the banding.  if it stays the same then I will ask mods to help you
a_e
Message 17 of 56
The router has now been restarted but it looks like the banding is still there. Although the upstream has gone up to 828.
xDSL
ModeADSL_2
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)7.29.1
Attenuation (dB)36.021.6
Output Power (dBm)19.212.2
Attainable Rate (Kbps)59761364
Rate (Kbps)2270828
K (number of bytes in DMT frame)00
R (number of check bytes in RS code word)00
S (RS code word size in DMT frame)00
D (interleaver depth)1608
Delay (msec)75
INP (DMT symbol)7.501.50
Super Frames2772815526
Super Frame Errors00
RS Words6987176469600
RS Correctable Errors14714
RS Uncorrectable Errors00
HEC Errors00
OCD Errors00
LCD Errors00
Total Cells1680990607318
Data Cells38671475852
Bit Errors00
Total ES00
Total SES00
Total UAS2323
Message 18 of 56
still stuck in banding  I have asked mods to help get you out of banding and they will post help here
Moderator
Moderator
Message 19 of 56
Hi @a_e Sorry that your profile is still banded.
We will be happy to help you get released from the banding if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
a_e
Message 20 of 56
Thanks @imjolly for referring me to the mods.
Hi @JohnC2, I've now filled out the form. In regards to releasing the banding, is that something that can be done your end?
