a_e
Message 31 of 56
Re: SNR fluctuation and banded after line upgrade
To keep this thread updated:
So, I’m still stuck in a banded profile (2272) and have been for 2 months (except for a few days when profile was reset)! My download speed is worse than on adslmax at around 1-1.96Mbps!
I had a power cut on Friday evening (23/02) and Saturday afternoon (24/02). I used this as an opportunity to replace the micro filter. No change. Quite line test still clear too.
I did have a massive surge of errors last night (Sun 25/02) which caused a resync.
Something that I’ve noticed which seems very odd is that the upstream SNR is fixed, absolutely no movement what so ever. Anyone know why that could be?
Any advice on what I’m meant to do next would be massively appreciated.
Message 32 of 56
you are not going to make any progress as long as your conenction keeps dropping and power cuts are not helping you.  see if mods can take another look and maybe get another engineer visit  there is no poit in releasing banding as long as connection keeps droppings as you found out last time
mods will post here again
a_e
Message 33 of 56
So does this sound like a line fault to you?
In the router stats, is there anything else which would give this away other than the SNR fluctuations? HEC and ES counts?
Thanks, I’ll await the mods.
Moderator
Moderator
Message 34 of 56
Hi @a_e It does look that something is not right here and removing the banding will won't resolve the issue on it's own.
Send us over your details again and we'll have another look at this for you. You can contact us by clicking on my user name and selecting contact the mods.
John
a_e
Message 35 of 56
Thanks @JohnC2
I'm not sure why but the 'contact the mods' link doesn't seem to be there like last time.
Moderator
Moderator
Message 36 of 56
Hi @a_e My apologies. Smiley Embarassed I've enabled it now.
cheers
John
a_e
Message 37 of 56
No worries 🙂 Thanks @JohnC2 , I've submitted the form now.
a_e
Message 38 of 56
Thanks very much to the mods for looking into this again, I really appreciate it!
After the work done yesterday, the connection rate went straight up to approx 5Mbps with a SNR of 6 Down/6 Up.
However, because I had an existing SNR tweak set on my router I had to quickly switch this off and back to the default because the SNR was at 0. After resync, rate decreased to 3744 where it has stayed.
SNR ranges from around 6 during the day and 2-3 at night.
I have noticed a lot of errors though.
Router stats below:
Line Rate - Upstream (Kbps)832
Line Rate - Downstream (Kbps)3744
Default Gateway / IPv4 Addresspppoa0 (DSL) / 86.140.34.57
Connection Time22:38:11
xDSL
ModeADSL_G.dmt
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)6.06.0
Attenuation (dB)36.023.5
Output Power (dBm)19.612.4
Attainable Rate (Kbps)3604940
Rate (Kbps)3744832
K (number of bytes in DMT frame)11827
R (number of check bytes in RS code word)00
S (RS code word size in DMT frame)0.500.50
D (interleaver depth)11
Delay (msec)0.130.25
INP (DMT symbol)0.000.00
Super Frames1078289710782897
Super Frame Errors73838756
RS Words00
RS Correctable Errors029
RS Uncorrectable Errors00
HEC Errors30063737
OCD Errors300
LCD Errors300
Total Cells7199474030
Data Cells1131428480
Bit Errors00
Total ES274660
Total SES1630
Total UAS18546
a_e
Message 39 of 56
Things are looking better!
Had a resync at 5:00am at a rate of 4Mbps with a SNR of 9.
Had another resync at 10:00am at a rate of 5Mbps with a SNR of 6.
Stats below:
xDSL
ModeADSL_G.dmt
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
SNR Margin (dB)6.46.0
Output Power (dBm)19.912.5
Attainable Rate (Kbps)5084932
Rate (Kbps)5056832
K (number of bytes in DMT frame)15927
R (number of check bytes in RS code word)60
S (RS code word size in DMT frame)1.001.00
D (interleaver depth)164
Delay (msec)4.002.00
INP (DMT symbol)0.290.00
Super Frames1244114912441149
Super Frame Errors1525021544
RS Words362884540
RS Correctable Errors1304172
RS Uncorrectable Errors53390
HEC Errors717851458
OCD Errors20
LCD Errors20
Total Cells1081777080
Data Cells336371780
Bit Errors00
Total ES474770
Total SES5540
Total UAS63566
Message 40 of 56
interleaved has now been applied
