a_e
Message 51 of 56
Re: SNR fluctuation and banded after line upgrade
Thanks @imjolly, that’s good to hear that the fibre installation isn’t a potential cause. I’m hoping to switch to fibre as soon as available, I just hope this problem doesn’t follow.
Thanks for the banded profile link. So I think it’s safe to say that the underlying issue hasn’t been fixed by Openreach! The continuous erratic noise margin resulting in a banded profile is still present and will continue to cycle round until the cause is fixed.
Robbie, the mod originally looking after this case said to post back if things don’t change, so I hope he sees this.
Message 52 of 56
when you switch to fibre then you are eliminating the copper cable from the exchange to your street cabinet and only leaving from cabinet to home as copper so hopefully that will eliminate the noise peoblem
a_e
Message 53 of 56
Unfortunately still haven’t heard from anyone at BT!
I’m at 10 days connection with banding still in place because of SNR fluctuations.
Is anyone available to take a look at this please?
Router stats and SNR graphs below.
Line Rate - Upstream (Kbps)864
Line Rate - Downstream (Kbps)3072
Default Gateway / IPv4 Addresspppoa0 (DSL) /
Connection Time10 Day(s) 17:12:51
xDSL
ModeADSL_G.dmt
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)24.99.0
Attenuation (dB)37.024.0
Output Power (dBm)18.812.5
Attainable Rate (Kbps)49201004
Rate (Kbps)3072864
K (number of bytes in DMT frame)9728
R (number of check bytes in RS code word)44
S (RS code word size in DMT frame)2.002.00
D (interleaver depth)84
Delay (msec)4.004.00
INP (DMT symbol)0.080.06
Super Frames105974966105974966
Super Frame Errors83622369
RS Words1852007361926001271
RS Correctable Errors53615
RS Uncorrectable Errors25950
HEC Errors609042391
OCD Errors10
LCD Errors10
Total Cells24141896880
Data Cells17351170210
Bit Errors00
Total ES23520
Total SES1100
Total UAS725627
2018-05-17-22.24.40-SNRMargin.pngSNRM - Thur 17th May2018-05-18-22.50.56-SNRMargin.pngSNRM - Fri 18th May2018-05-19-22.43.02-SNRMargin.pngSNRM - Sat 19th May2018-05-20-22.25.21-SNRMargin.pngSNRM - Sun 20th May2018-05-21-15.28.39-SNRMargin.pngSNRM - Mon 21st May
Message 54 of 56
the new graphs are showing a more stable noise margin apart from the odd dropps which some are quite significant.  I think if you were to get out of banding then these significant noise margin drops would be enough to drop your conenction and if continued would put you back in a banded profile
any idea when fibre is coming to your area  http://dslchecker.bt.com/adsl/adslchecker.welcome   enter your phone number and see if anything
a_e
Message 55 of 56
That’s the thing, I can get a day where the SNR is very steady like the Friday 18th May example above and then the following day I get quite a dramatic burst or series of them.
That’s exactly what keeps happening. OpenReach reported that the fault had been fixed but the SNR is still dropping too extremely which means I keep going back into a banded profile.
The availability checker just shows ‘Planned’ for fibre availability, which is a bit vague. I’ve pressed OpenReach for a date but they couldn’t commit to one which is understandable. CodeLook says April 2018 for Cab E5 and July 2018 for Cab P5.
a_e
Message 56 of 56
My banded profile has now been lifted after 13 days connection and 3 days of fairly (but not perfect) stable noise margin. However, I fear banding will be back if this noise issue resurfaces.
I’m now synced at 5.4 down, 832 up with a SNR margin of 16dB down, 10dB up.
On a side note regarding the fibre cabinet - I noticed the silver lock on the new cabinet on Monday, however, it could have been there longer. Going by other people’s experiences, it usually takes 1-4 days from that point but I understand it can take longer. Availability checker is still showing ‘planned’ and OpenReach is saying ‘Activate’ so my fingers remain crossed that it will be in the next few weeks.
