PS61
Message 1 of 15
Short Dropouts still happening after engineer visits.
My speeds dropped from 80mb down to 20mb and I was having dropouts multiple times a day lasting a couple of minutes at a time. A BT engineer came out, said their was nothing wrong with the setup inside the house, confirmed the speed coming in was 18mb instead of 80mb and that I needed an OpenReach engineer.
The OpenReach engineer did his testing and replaced the socket with the latest frontplate. There were a few longer disconnects later that day as the engineer said there would be, but the speed would return to what I paid for and the dropouts would stop.
I use Google WiFi connected to the white BT modem but I swapped that setup out for the Smart Hub for the engineer visits. Before I moved back to my Google WiFi setup the Hub Manager was showing a 79mb speed was coming into the hub but still with the occasional dropout (Hub light flashing orange, then back to blue after a couple of minutes.)
I’m wondering what my next step is, since the Google WiFi speed is maxing out at 45. Should I have left the Smart Hub as my router from longer than I did after the engineer visit? The next thing I am thinking is should I replace my DSL cable since everything else has been swapped out/reset?
14 REPLIES 14
Message 2 of 15
Re: Short Dropouts still happening after engineer visits.
Can you access the stats in the modem and if so can you post
any line noise. Dial 17070 option 2 should be silent and best with corded phone
Moderator
Moderator
Message 3 of 15
Hi @PS61
Please reply with the info that @imjolly is asking for and we'll take things from there 😊
Cheers,
Robbie
PS61
Message 4 of 15
I did the quiet line test. I only have a cordless phone so that’s the best I can do. There’s no crackling or anything obvious I’d consider noise, but I’m not an expert.  The speed did rise briefly late last night to between 68-75 but it’s back down to the 40’s today.
Message 5 of 15
Can you post connection stats
Are the speeds you are quoting in last post download speeds instead of connection speeds?
PS61
Message 6 of 15
Those are the downloads speeds. I’d have to swap the Google WiFi + OpenReach modem for the Smart hub to check the connection speed, unless there’s a way to do that when using the OpenReach modem?
Message 7 of 15
You need to have unlocked modem to get stats otherwise only way is to use hub without the modem
download speeds can fluctuate all the time - are you using Ethernet or wifi to measure download speed?
PS61
Message 8 of 15
So I plugged the Smart Hub back in. In the Hub Manager it’s saying Downstream sync speed 67, Upstream sync speed 20. So I’m still not at the 80 I was getting before.
Message 9 of 15
if hub connected then post stats  if hh6 then advanced settings then technical log information
enter phone number and post results  delete number but leave exchange and cab  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
it's common for connection speed to reduce as more people are added to your cabinet due to crosstalk
PS61
Message 10 of 15
