shewolf
Message 1 of 14
Sky told me it’s down to BT
Hello, I’m with Sky and I can have great MBPS and then it drops to nothing.
I have spent much time in the phone changing channels etc.
When will BT be upgrading its whole system to fibre? We are about twelve houses away from the cabinet.
Sky say it’s up to BT update the cable.
Virgin is not available in our street.
I did a DSL checker but can’t seem to attach it.
Just very fed up of constant buffering.
Any suggestions?
13 REPLIES 13
Message 2 of 14
Re: Sky told me it’s down to BT
Its Openreach not BT Retail that are responsible for the external infrastucture. As this is just a BT Retail customer forum, you need to ask Openreach when you are likely to get a faster connection.
https://www.homeandbusiness.openreach.co.uk/fibre-broadband/when-can-i-get-fibre
shewolf
Message 3 of 14
Thank you very much. Is it then I need to speak to about FTTP as well
Message 4 of 14
FTTP is only provided in certain areas, and there are only a few providers that offer it.
All you can do is ask.
XRaySpeX
Recognised Expert
Message 5 of 14
You probably mean FTTC. Doubt Sky do FTTP.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Message 6 of 14
Sky do not offer FTTP only fibre to cabinet
shewolf
Message 7 of 14
No, I was asking BT with a view to moving to them.
This won’t happen imminently. Or likely not for 8 years!
shewolf
Message 8 of 14
Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
High Low High Low
VDSL Range A (Clean) 80 67.3 20 19 59.5 Available -- -- --
VDSL Range B (Impacted) 80 60 20 18.9 44 Available -- -- --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- -- --
ADSL Products
Availability Date
WBC ADSL 2+ Up to 17 -- 10 to 19.5 Available -- -- --
WBC ADSL 2+ Annex M Up to 17 Up to 1.5 10 to 19.5 Available -- -- --
ADSL Max Up to 7.5 -- 6.5 to 8 Available -- -- --
WBC Fixed Rate 2 -- -- Available -- -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- -- --
ADSL Multicast -- -- -- Available -- -- --
XRaySpeX
Recognised Expert
Message 9 of 14
You don't have FTTP there. Only FTTPoD (on Demand), an expensive product designed for businesses.
However you should be able to get the top end of FTTC.
shewolf
Message 10 of 14
That’s what Sky say. I’m paying for Fibre Max-which is up to 76MBPS which I sometimes get, but then I get nothing as well. It’s most obvious when the children play their online games, or we stream programmes.
