Message 1 of 5
Slow Broad band
I get barely over 8mbps on my 17mbps deal. Is this acceptable?
4 REPLIES 4
Message 2 of 5
Re: Slow Broad band
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 5
Re: Slow Broad band
speeds are sold as UP TO speeds and the speed you get depends on the distance you are from the exchange post bac the information asked for in the post above and ewe can then help you further
Message 4 of 5
Re: Slow Broad band
enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
Distinguished Guru
Message 5 of 5
Re: Slow Broad band
Some people only get 0.5mbps.  It's all dependent on the length of your line back to the exchange.
