pine
Message 1 of 10
Slow Broadband Issues - throughput and IP profile
Hi,
I have been helped a few times in the last years by the Moderators of this Forum, which were the only reasons I remained with BT, so would hope to get help again with an issue tha presented itself since a couple of days. No particular help from the telephone cusotmer service, as usual....
Basically, my BT Broadband is normally at an IP Profile of approx. 4mb, with a download speed of 4mb and upload speed of 800kb. I have BT home hub 4 which normally syncs very close to the above values.
However, a few days ago there was a disconnection (just once), and the hub reconnected at about 3mb download 700kb upload. Yesterday, with the hub still connected at those sync speeds (i.e no more disconnections), I noticed the internet was unusable, and running speed tester found the download throughput speed was almost zero. After 1 hour, it went back up again to approx. 2.5mb download, then after some time again down to near unusable. The upload speed was unaffected, and the hub did not lose disconnection. There has been this issue since, and I attach below two images showign the bt speed test made at a distance of 1 hour showing the parameters.
Previous issues I had on the line had to do with problems on the actual copper between the cabinet and exchange, which were eventually sorted after intervention of Moderators. I don't think this time the problem is an issue on the actaul coppers, as there are no disconnections, but there is high instability in the throughput speed. I also noticed from the checks that the IP profile, whcih usedto be approx. 4mb, has dropped to 2.93mb, and the max dowmload speed I am getting is about 2.5-2.8 now.
Can I please ask advice on what to do to solve this, customer service by phone could see there is slow speed but was of no help ratehr than suggest monitoring how it goes... I would really like a Moderator to look into the line to see where the issue can be and maybe advise if a re-profile is possible, bearing in mind the hub connection seems stable.
Also I am at the master socket, ethernet cabel and 1 computer only at moment and no issues whatsoever at my end.
Pine
9 REPLIES 9
Message 2 of 10
Re: Slow Broadband Issues - throughput and IP profile
if you have extension sockets in other rooms cab you try conencting to the test socket to eliminate internal wiring problems
try quiet line tes  dial 17070 option 2   should be quiet and best with corded phone
your profile is 88.2% of your conenction speed so to get a higher profile you beed a faster conenction speed
if you go to hub manager then helpdesk and logs/wan and post the 2 lines together which show your connection speed and your noise margin
pine
Message 3 of 10
Thanks for the reply, 17070 option 2 is clear, I am connected to test socket and the values for the hub are as per below:
16:29:04,14 Feb. ( 108.390000) DSL noise margin: 5.90 dB upstream, 7.20 dB downstream
16:29:00, 14 Feb. ( 104.650000) DSL line rate: 859 Kbps upstream, 3864 Kbps downstream
Unfortunately, nothwistandign those values, it is now 2 hours that the speed is almost zero and can barely browse, right now is
I could do with some help from moderators as I have practically no internet now.
pine
Message 4 of 10
as you are on adsl2 your profile is correct as it is 88.2% of your connection speed  so to get higher profile you need faster connection speed
can you run btspeedtster again but this time run diagnostic test that follows first test - must be done wired
btspeedtester
pine
Message 5 of 10
Hi,
Unofortunately as you can see the download speed is now so low that the connection times out so I cannot run any test at present.
How many days without usable Internet should we be before requesting compensation from BT? I also pay BT SPort that cannot see now
Message 6 of 10
if you are connected to the test socket with a new filter and using ethernet conenction to pc is your download speed low all day or only at peak times?
check to see if there are any exchange problems  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
pine
Message 7 of 10
Hi thanks, I am connected to test socket with ethernet. Today has been horrible all day, I now just managed to run the tests again as requested, here they are:
Message 8 of 10
did you check the links for problems in your area?  is speed low all the time or just peak times.  do you know if neighbours are also have problesm with slow download speed?
pine
Message 9 of 10
Hi, It seems the problem is there all the time both peak and off peak. Checked with neighbours and they have no issues, also checked issues in the links above and nothing reported in our area, so we are at a loss, even cannot look at emails now.
Tags (1)
Message 10 of 10
if your neighbours are not experiencing problems with download spped and they are not on cable then it does not appear to be exchange congestion problem and more likely a problem with just your conenction.  have you tried phoning customer services and getting engineer visit?
08001114567
  Faults  0330 123 4567
