jonneh
Message 21 of 26
Re: Slow Internet speeds/Noise on phoneline.
Yeah everytime its been reset previously, it slowly deteriorates and the connection gets worse over time.
Message 22 of 26
many connection benefit from running with 3db but some others like yours find that it is to low and it increases the errors resulting in slow throughput
Message 23 of 26
although if you increase the noise margin to 9 dB will reduce the connection speed I would suggest getting it reset to 9dB as it will give the MSAN a little more training history which may help in not reducing below 6dB
jonneh
Message 24 of 26
So what would you recommend I do to get BT to fix this?
Message 25 of 26
I would contact mods and ask for the noise margin to be reset to 9db as john46 suggested and this should help reduce the errors and improve download.  remember the increase in noise margin will reduce your connection speed
jonneh
Message 26 of 26
Yeah I've messaged then, i'd rather have a stable connection and sacrifice a bit of speed. This problem has been going on for nearly a year.
