mkay
Message 1 of 8
Slow Internet...
Hi, I've been away for a while, returned to find completely dead phone and slow internet. The engineers called last week and replaced cables etc. He told me the internet speed should come back automatically
after 3 or 4 days, if not ask for it to be done manually. Well it's still slower than normal 5 days on, so can someone fix it please. I hope this is the right place to ask. Speed test figures etc. below:
1. Best Effort Test: -provides background information.
    Download  Speed
    0.98 Mbps
0 Mbps    1 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.98 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-1 Mbps.
 IP Profile for your line is - 1.01 Mbps
2. Upstream Test: -provides background information.
    Upload Speed
    0.76 Mbps
0 Mbps    0.83 Mbps
Upload speed achieved during the test was - 0.76Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
ADSL line status
Connection Information
Line state    Connected
Connection time    4 days, 22:52:56
Downstream    1,151 Kbps
Upstream    1,132 Kbps
ADSL Settings
VPI/VCI    0/38
Type    PPPoA
Modulation    G.992.5 Annex A
Latency type    Interleaved
Noise margin (Down/Up)    23.6 dB / 6.1 dB
Line attenuation (Down/Up)    26.1 dB / 9.1 dB
Output power (Down/Up)    19.3 dBm / 1.7 dBm
Loss of Framing (Local/Remote)    0 / 0
Loss of Signal (Local/Remote)    0 / 0
Loss of Power (Local/Remote)    0 / 0
FEC Errors (Down/Up)    1007 / 0
CRC Errors (Down/Up)    0 / 0
HEC Errors (Down/Up)    0 / 0
Error Seconds (Local/Remote)    0 / 0
7 REPLIES 7
Message 2 of 8
Re: Slow Internet...
You are in a banded profile you need to maintain a stable connection with no hub restarts for 10 days and you will come out of the banding automatically
this link should help you http://forumhelp.dyndns.info/speed/speed_drop.html
Message 3 of 8
you are in a banded profile and this normally releases in 3/5 days but as you are almost at 5 days stable connection I would contact the mods as it may be stuck.  if it releases in the 3 days it may take mods to contact you then great
contact mods
can take up to 3 working days for mods to contact you
mkay
Message 4 of 8
Thanks for the very prompt replies, caught me out. I've contacted mods so fingers crossed. I'll let you know.
Message 5 of 8
can you post new stats when mods get you out banding please   just for reference
mkay
Message 6 of 8
Had an email from mods yesterday evening to say they have 'reset your profile as you have requested. This should take between 4 and 8 hours to complete' but 10 mins later I was back up to full speed. Amazing service and thanks to you and mods. Below are stats:
    Download  Speed
    15.57 Mbps
0 Mbps    21 Mbps
 Download speedachieved during the test was - 15.57 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 16.53 Mbps
    Upload Speed
    0.99 Mbps
0 Mbps    0.83 Mbps
Upload speed achieved during the test was - 0.99Mbps
ADSL line status
Connection time    0 days, 09:30:48
Downstream    18,740 Kbps
Upstream    1,199 Kbps
ADSL Settings
VPI/VCI    0/38
Type    PPPoA
Latency type    Fast
Noise margin (Down/Up)    4.9 dB / 6.3 dB
Output power (Down/Up)    27.6 dBm / 1.8 dBm
FEC Errors (Down/Up)    0 / 0
CRC Errors (Down/Up)    53284 / 0
HEC Errors (Down/Up)    56236 / 0
Error Seconds (Local/Remote)    6861 / 0
Message 7 of 8
looking better nowSmiley Wink
Message 8 of 8
pleased every thing is now all resolved
