Message 11 of 26
Re: Slow connection and no help from call centre.
@Derrymilk
The big difference you are trying to upgrade to fibre not move from adslmax to adsl2
mods will help just a matter af waiting till mods get back to you
Derrymilk
Message 12 of 26
@imjolly na, trying to stay on tha ADSL and get service I had 2 weeks ago
Rrratty
Message 13 of 26
Hi Robbie,
Not really noticed much difference in speed. Speed tests this week have been averaging about 1.75mb down and .65 up. Not sure when the switch over was done, does it take a while to settle down?. Just can't understand why I was getting around 5mb with sky on the same line. Also noticed my ping has now shot up to above 500ms, sometimes up to 1000ms.
Message 14 of 26
can you post the adsl stats from your router
it may have been same line but different exchange equipment as SKY have their own in the exchnage.  still speeds should be similar
Rrratty
Message 15 of 26
13:31:32, 07 Jan. DSL Link Up: Down Rate=2187Kbps, Up Rate=698Kbps; SNR Margin Down=6.2dB, Up=6.3dB
Message 16 of 26
if you have the hh4 can you post stats from helpdesk please.
are you using the test socket with a new filter?
certainly looks like you have move to adsl2
Rrratty
Message 17 of 26
1. Product Name: HomeHub4
2. Serial number: +076281+1523008253
3. Firmware version: v0.07.01.0910-BT (Type B) Last updated [Unknown]
4. Board version: 01A
5. DSL uptime: 0 days, 03:56:57
6. Data Rate: 698 / 2187
7. Maximum Data Rate: 700 / 2044
8. Noise Margin: 5.8 / 4.8
9. Line Attenuation: 42.1 / 64.5
10. Signal Attenuation: 42.0 / 65.8
11. Data sent/received: 24.1 MB / 588.9 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
14. 2.4GHz wireless network/SSID: BTHub4-9GZR
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA & WPA2 (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: BTHub4-9GZR-5ghz
19. 5GHz wireless connections: Enabled (802.11 n (up to 300 Mb/s))
20. 5GHz wireless security: WPA2 Only
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 5c:dc:96:6b:f0:c3
24. VPI/VCI: 0/38
25. Modulation: G.992.5(ADSL2+)
26. Latency type: Fast
27. Software variant: -
28. Boot loader: 0.4.3-BT (Mon Jun 9 14:23:56 2014)
Message 18 of 26
as you can see you are on adsl2+  992.5 so definately moved from adslmax  with your attenuation of 64.5db that would give a connection speed of about 2mb ewhich is about the speed you have.  you speed is actually above that shown for attainable probably due to noise margin at 4.8db
are you using test socket?
Rrratty
Message 19 of 26
No I'm not using the test socket, I'll swap tomorrow and post those results. In the mean time what could be causing suchm high pings and also why were my speeds so much better with sky, do they have better equipment in the exchange?
Message 20 of 26
Sky just use there own equipment and provide  an LLU service but normally you would expect adsl2 to give similar results. However with the current attenuation you are not going to get much if any faster - unless using the test socket helps
