Message 11 of 58
Re: Slow peak speeds :(
can you run the BT speedtest http://speedtest.btwholesale.com/ and complete the further diagnostics part of the test at several times tommorow say early morning midday early evening and around 9pm so we can see how the speed varies through the day
pmk24
Message 12 of 58
ok i didnt get chance on friday but here are todays results
8:50am
12:30
15:30
17:04
and 21:00
However like i said in my first post, the speed acheived on the btw speedtest is not what i am getting to the pc, it took 5-10 minutes to get to and complete the test 😞 webpages and anything just takes minutes to load!
Any ideas as this completely renders my connection useless untill 1am or so.
Hope everyones haveing a good weekend tho 🙂
Paul
Message 13 of 58
those test results are the speed at your PC the only low result is the 21:00 one although that is still within BT Wholesale spec
pmk24
Message 14 of 58
Thanks for replying to my post, however did you read the part where i clearly have written both in my original post and just that I am not troubleshooting about the reported connection speed through tthe BTW report but the actual speed and latency at peak times. The speed reported is fine but in reality as soon as i try and load a webpage or do anything it can take minutes to respond.
Message 15 of 58
is anything shown here for your exchange http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
Another possibilty is high crc/hec errors at peak times but the hh4 does let you get the stats to see iftat isthe case
pmk24
Message 16 of 58
nope nothing reported and all green for faults
Message 17 of 58
Did you report the line noise in your previous post? Is there still noise on quiet line test?
pmk24
Message 18 of 58
[quote]
ok, so after going through 151 and doing the diagnostics on the line I had found out the handset i was using was a bit dodgy (cable would flex and cause the crackle) so now with a new phone it is clear of any crackles, pauses or gaps.[/quote]
The line seems fine now with no crackles with the new handset
Message 19 of 58
please post a traceroute to bbc.co.uk using command prompt and post back those results
pmk24
Message 20 of 58
Line back up to speed again now just fine so will post tomorrow when it goes slow again
