Message 21 of 58
Re: Slow peak speeds :(
a trace route showing as things are now and when the problem appears would be of help
pmk24
Message 22 of 58
ok 2x tracerts when the internet speed is ok
C:\Users\pmk>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.244.69] over a maximum of 30 hops:
1     11 ms     1 ms     2 ms  BThomehub.home [192.168.1.254]
2     7 ms     7 ms     6 ms  172.16.13.131
3     *        6 ms     6 ms  217.41.217.110
4    20 ms     7 ms   121 ms  217.41.217.109
5     8 ms     8 ms     8 ms  212.140.235.130
6     8 ms     8 ms     9 ms  217.41.169.33
7     8 ms     8 ms     8 ms  217.41.169.107
8     8 ms     7 ms     7 ms  109.159.251.83
9    18 ms    16 ms    22 ms  core2-te0-13-0-2.ilford.ukcore.bt.net [109.159.2 51.11]
10    14 ms    13 ms    14 ms  peer2-xe2-1-0.telehouse.ukcore.bt.net [109.159.2 54.142]
11    14 ms    14 ms    14 ms  194.74.65.42
12     *        *        *     Request timed out.
13     *        *        *     Request timed out.
14    18 ms    16 ms    18 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
15    14 ms    17 ms    15 ms  132.185.255.149
16    15 ms    14 ms    14 ms  bbc-vip114.telhc.bbc.co.uk [212.58.244.69]
Trace complete.
1     2 ms     2 ms     2 ms  BThomehub.home [192.168.1.254]
2     7 ms     6 ms     6 ms  172.16.13.131
3     7 ms     7 ms     6 ms  217.41.217.110
4     6 ms     26 ms     76 ms  217.41.217.109
6     8 ms     8 ms     8 ms  217.41.169.33
8    10 ms     8 ms     7 ms  109.159.251.75
9    20 ms    23 ms    15 ms  core2-te0-13-0-2.ilford.ukcore.bt.net [109.159.2 51.11]
10    13 ms    14 ms    16 ms  peer1-xe3-2-0.telehouse.ukcore.bt.net [109.159.2 54.221]
11    14 ms    14 ms    15 ms  194.74.65.42
14    15 ms    18 ms    28 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
15    16 ms    18 ms    14 ms  132.185.255.149
16    14 ms    15 ms    14 ms  bbc-vip114.telhc.bbc.co.uk [212.58.244.69]
Trace complete.
pmk24
Message 23 of 58
now this is when my net is fine, but looking at the tracert hop4 seems to spike somtimes, so i did 2x pings to it
C:\Users\pmk>ping 217.41.217.109 -t
Pinging 217.41.217.109 with 32 bytes of data:
Reply from 217.41.217.109: bytes=32 time=10ms TTL=252
Reply from 217.41.217.109: bytes=32 time=6ms TTL=252
Reply from 217.41.217.109: bytes=32 time=7ms TTL=252
Reply from 217.41.217.109: bytes=32 time=135ms TTL=252
Reply from 217.41.217.109: bytes=32 time=8ms TTL=252
Ping statistics for 217.41.217.109:     Packets: Sent = 37, Received = 37, Lost = 0 (0% loss), Approximate round trip times in milli-seconds:     Minimum = 6ms, Maximum = 135ms, Average = 9ms
Control-C ^C
Reply from 217.41.217.109: bytes=32 time=92ms TTL=252
Reply from 217.41.217.109: bytes=32 time=11ms TTL=252
Reply from 217.41.217.109: bytes=32 time=116ms TTL=252
Reply from 217.41.217.109: bytes=32 time=23ms TTL=252
Reply from 217.41.217.109: bytes=32 time=29ms TTL=252
Ping statistics for 217.41.217.109:     Packets: Sent = 57, Received = 57, Lost = 0 (0% loss), Approximate round trip times in milli-seconds:     Minimum = 6ms, Maximum = 116ms, Average = 10ms
Control-C ^C
C:\Users\pmk>
Message 24 of 58
ok thanks please try the same when the connection slows down
pmk24
Message 25 of 58
  1     2 ms     2 ms     3 ms  BThomehub.home [192.168.1.254]
2     6 ms     6 ms     7 ms  172.16.13.131
3     6 ms     6 ms     6 ms  217.41.217.110
4     7 ms     6 ms     7 ms  217.41.217.109
6     7 ms     7 ms     8 ms  217.41.169.33
7     9 ms     9 ms     8 ms  217.41.169.107
8    10 ms     8 ms     8 ms  109.159.251.83
9   368 ms   287 ms   167 ms  core2-te0-13-0-2.ilford.ukcore.bt.net [109.159.2 51.11]
10   265 ms   273 ms   275 ms  peer1-xe3-2-0.telehouse.ukcore.bt.net [109.159.2 54.221]
11   231 ms   143 ms   155 ms  194.74.65.42
14    18 ms    19 ms    18 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
15    18 ms    17 ms    15 ms  132.185.255.149
16    14 ms    13 ms    14 ms  bbc-vip114.telhc.bbc.co.uk [212.58.244.69]
Trace complete.
Reply from 217.41.217.109: bytes=32 time=121ms TTL=252
Request timed out.
Reply from 217.41.217.109: bytes=32 time=102ms TTL=252
Ping statistics for 217.41.217.109:     Packets: Sent = 46, Received = 45, Lost = 1 (2% loss), Approximate round trip times in milli-seconds:     Minimum = 6ms, Maximum = 121ms, Average = 10ms
Control-C ^C
C:\Users\pmk>
and as by magic 5 minutes later its back at
Just to make things clear, I am the only thing connected to the home hub, nothing is downloading or causing traffic on my PC or it would be reported via netlimiter
All i want is a good and stable connection so I am able to use the internet
Regards
Paul
Message 26 of 58
it does look like some peak time network congestion but as your speeds are currently in spec there is little that can be done
pmk24
Message 27 of 58
so in peak hours (basicly the time I am at home) I am unable to use my internet connection and this is ok?
I honestly am really puzzled how BT expect anyone to be happy with this level of service of connection, I understand that this is a community forum but even if the BTW page said my connection is 2mb or 20mb all the time it still does not help resolve that when i use the internet the connection is terrible and not function correctly.
Message 28 of 58
there is nothing BT retail your provider can do as the network is provided by BT Wholesale to the majority of ISPs and unless speed drop below their minimum fault level which in your case is 4mb they will not act on it
pmk24
Message 29 of 58
John,
I think either I have not explained my issue correctly or you think I am complaining about this magic number that is displayed on a webpage that does not help my issue at all.
At peak hours, I am unable to use the internet for anything other then browsing and email. It does not matter that I connect to the internet at a value and as by magic if this value is green then my connection must be fine .... It isn't fine.
I am seeking help or advice in getting a service that I pay for to an acceptable level. If I was sold with the knowledge that I would get in reality a very weak line I would not be complaining as much, however something is wrong somewhere and it needs to be fixed.
Message 30 of 58
your problem certainly looks like exchnage congestion at peak time just as thought earlier but from your btspeedtester results your download speed is always above the acceptable limit/threshold shown and from previous experience wholesale do not normally help in these cases.
john46 and I are not saying we agree with that just that is the way wholesale have been in similar situations to yours in the past
