Message 41 of 58
Re: Slow peak speeds :(
Same as before with download speed above the acceptable level
pmk24
Message 42 of 58
Message 43 of 58
Wholesale will only accept figures from their own btspeedtester. Still looks like congestion
pmk24
Message 44 of 58
I dont know how else to explain the issue then, if you brought a car and it only traveled at 20mph when its engine has is tested at 120mph is the closest i can say. I am not getting the speed advertised from the BTW website and no matter how many more screen shots i take will not change that.
pmk24
Message 45 of 58
if its congestion would my neighbour have the issue?
Message 46 of 58
Congestion would normally affect the exchange and wholesale do upgrade the exchanges
pmk24
Message 47 of 58
As a BT customer would it be possible that an admin would give 5 minutes of their time to discuss with me that issue that I am having? I dont mind ringing them or discussing via email or a webchat.
Message 48 of 58
You could always try bt care on twitter
This is the kitz pae about exchange congestion. http://www.kitz.co.uk/adsl/slowspeeds.htm
SgtAMYNTAS
Message 49 of 58
I know this Sounds Stupid but Do Not Connect to the GigE Port Ethernet on the Bt Hub 4. You may Have a Firm ware or Bios Problem with your Computer Like Mine that shows "In-Accurate Results" Always Connect Via Port 1 or 2 With a Standard Cat5 Cable Supplied with BT or Just use the Wireless that Gives the Best Test Results "My Opinion".
MSDN Developer, Nokia Developer, Xbox Ambassador XB-8, Network & Diagnostic Tester/ Coder IPX/ISO Moderator.
Message 50 of 58
really be surprised if changing router port will help your exchange congestion
