pmk24
Message 51 of 58
Re: Slow peak speeds :(
@BTCARE are as bad as ringing up 1st line as I was instantly told that its a wireless channel fault when i said I am directly connected to my HH ........ and if i get slow internet, keep on restarting my home hub as it would help 😞
Please if an admin could just spend 5 minutes of time to talk to me so I can ask 2 questions it would be greatly appreciated.
Paul
Message 52 of 58
what does your exchange show  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
pmk24
Message 53 of 58
everything is green and no faults. well apart from 300ms pings and 0.7mb speed but thats ok because the BTW website says my connection is fine .... perhaps i will look and get a ADR involved?
pmk24
Message 54 of 58
and even though i have followed the instructions to disable bt wifi (http://bt.custhelp.com/app/answers/detail/a_id/12958/c/346,1238,2694) weeks ago my router still is sharing the service when i turn my wifi back on from doing BTW speed checks.
Hopefully on monday an admin will be in touch.
Message 55 of 58
You can try opting in then opting out as that has helped posters before. Often your hub needs a reset to change the setting
What are the btspeedtester figures like tonight?
pmk24
Message 56 of 58
up and down like a tarts knickers i'm afraid 😞 just logged into another persons wifi that I have bribed (with beer) access for and they are fine.
Could it be the homehub?
Message 57 of 58
It's always possible and only way to test. IS to try another router even for just a few days and see if that solves it
You can also try CS and see if you can persuade them that router faulty and they should send a replacement
Message 58 of 58
it can take around a month for BT Wifi to disable occasionally
