garymid
Message 1 of 17
Slow speed with BT Hub 3
I have resently changed from a Hub 2 to a Hub 3 due to a fault with my Hub 2. With the Hub 2 i was getting around 3Mb.
Now with the Hub 3 i am only getting 0.25Mb. Can you please help.
ADSL Line Status
Connection Information
Line state:Connectedppp0_0
Connection time:2 days, 12:59:50
Downstream:287.4 Kbps
Upstream:888.9 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Interleaved
Noise margin (Down/Up):8.5 dB / 7.1 dB
Line attenuation (Down/Up):54.7 dB / 33.2 dB
Output power (Down/Up):16.1 dBm / 12.6 dBm
FEC Events (Down/Up):14633390 / 10971
CRC Events (Down/Up):0 / 47
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 23
Error Seconds (Local/Remote):0 / 11
16 REPLIES 16
Message 2 of 17
Re: Slow speed with BT Hub 3
are you connected to the master or better still the test socket?  is quiet line test ok - should hear nothing  dial 17070 option 2 and best with corded phone  if cordless then dull hum normal
garymid
Message 3 of 17
These are my new stats. I have better downstream now but the internet still feels slow. Can't even watch a video on youtube. I was wondering if i would get better speed if i was on interleaved instead of fast due to the amount of errors i am getting.
ADSL Line Status
Connection time:1 days, 06:15:49
Downstream:3.211 Mbps
Upstream:915.8 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):6.4 dB / 5.9 dB
Line attenuation (Down/Up):53.2 dB / 33.3 dB
Output power (Down/Up):17.3 dBm / 12.6 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):3097240 / 127
HEC Events (Down/Up):1209876 / 60
108827 / 125
Message 4 of 17
are you connected to the test socket?  are you using a new filter and no extension lead   quiet line test ok?
check this post http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
garymid
Message 5 of 17
Yes i'm using test socket and new filter and no extensions. Quiet line test ok.
Message 6 of 17
there is something causing large numbers of crc/hec errors and error seconds and that is the reason your download/throughput is slow even though your connection speed is 3mb+
If you are conencted to the tes socket, tried new filter, quiet line test ok and not using an extension then you needd to contact the mods for help to get rid of your noise problem - change to interleaving would help
contact mods
can take up to 3 working days for mods to contact you
garymid
Message 7 of 17
I am back on interleaved now and the internet is more usable now. But should i be getting this many FEC events and what could be causing it.
ADSL Line Status
Connection time:0 days, 22:48:15
Downstream:3.179 Mbps
Upstream:949.3 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):7.1 dB / 5.4 dB
Line attenuation (Down/Up):53.5 dB / 33.3 dB
Output power (Down/Up):17.2 dBm / 12.6 dBm
FEC Events (Down/Up):56888285 / 3311
CRC Events (Down/Up):27 / 171
HEC Events (Down/Up):222 / 92
Error Seconds (Local/Remote):185539 / 413
Message 8 of 17
FEC errors are due to interleaving doing it's job.  I would be more concerned with the high number of error seconds suggesting line noise still
garymid
Message 9 of 17
My Hub has reset again and speed when running bt speedtester has dropped to 1.28Mb.
What has happen to my modulation?
ADSL Line Status
Connection time:0 days, 00:13:34
Downstream:3.306 Mbps
Upstream:896.6 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:Unknown or no mode configured
Noise margin (Down/Up):4.0 dB / 7.1 dB
Line attenuation (Down/Up):55.1 dB / 33.4 dB
Output power (Down/Up):17.7 dBm / 12.6 dBm
FEC Events (Down/Up):2699823 / 0
CRC Events (Down/Up):20473 / 0
HEC Events (Down/Up):8960 / 0
789 / 0
Message 10 of 17
the modulation will correct itself.
your slow throughput is due to the high number of crc/hec errors and errors seconds.  fec errors are ok and interleaving working
