Chris92
Message 1 of 5
Slower Upload Speed
Hey there folks, I have a similar problem to the guys who have posted previously. I just moved house and brought my BT connection with me, and my download speeds have improved but my upload speeds are slower. I understand download speeds are prioritised and I'm not expecting miracles, but could anything be done to help improve it?
Here are my results from the speedtester:
 Download speedachieved during the test was - 6.94 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
4 REPLIES 4
Message 2 of 5
Re: Slower Upload Speed
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Chris92
Message 3 of 5
Hey John, thanks for the reply. Here are the results:
ADSL Products
ADSL MaxUp to 1.5--1.5 to 4Available----
Fixed Rate1----Available----
FTTC is currently not available on this cabinet due to following reasons:- This cabinet is under review. We'll explore fibre broadband solutions & will update once done..
WBC SOGEA is currently not available on this cabinet due to following reasons:- This cabinet is under review. We'll explore fibre broadband solutions & will update once done..
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market B Exchange.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Message 4 of 5
you are on ADSL Max and your upload speed is the best you can achieve at this time
Chris92
Message 5 of 5
Okay thank you for the help anyway.
