Message 81 of 131
Re: Speed could be better?
post back and let us know how you get on
RipandBurn
Message 82 of 131
Unfortunately, my daughter took the call, heard an accent and put the phone down - we get plauged by "sales calls" (not what I call them.......).  I got an e-mail saying they had called and to e-mail back - I did and heard nothing.  Since then, the hub also restarted and is now even slower.
I think I used the e-mail I got from Adrian but it looks like a generic e-mail address - is there another I should have used?
Stats for completeness
ADSL Line Status
Connection Information
Line state:Connectedppp0_0
Connection time:5 days, 20:55:22
Downstream:2.531 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):14.6 dB / 19.0 dB
Line attenuation (Down/Up):44.1 dB / 28.0 dB
Output power (Down/Up):18.8 dBm / 11.9 dBm
FEC Events (Down/Up):8359 / 235
CRC Events (Down/Up):809 / 82
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):644 / 45
Error Seconds (Local/Remote):740 / 60
Message 83 of 131
no that email will have been ok he may be off shift for a few days
RipandBurn
Message 84 of 131
still nothing - so did the punishable crime and manual restart - better than before, although still "could be better"
ADSL Line Status
Connection time:0 days, 00:01:44
Downstream:2.969 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):15.6 dB / 19.0 dB
Output power (Down/Up):18.7 dBm / 11.9 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):1 / 5
HEC Events (Down/Up):0 / 0
Error Seconds (Local/Remote):1 / 1
Message 85 of 131
Unfortunately that reset has put you back on a 3 day wait until the margin can either be reset manually by the mods
Moderator
Moderator
Message 86 of 131
Hi RipandBurn,
Thanks for posting. Once you've hit the 3 days stable period drop me an email with the details and I'll take a look at this for you. You'll get the 'contact us' link in my profile.
Cheers
David
RipandBurn
Message 87 of 131
Thanks David, I will go on the link tomorrow when I have the required 3 day connection.
RipandBurn
Message 88 of 131
The 3 day stats and I will get the link for David.
ADSL Line Status
Connection time:3 days, 09:39:05
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):14.2 dB / 19.0 dB
FEC Events (Down/Up):6543 / 81
CRC Events (Down/Up):704 / 41
HEC Events (Down/Up):725 / 16
Error Seconds (Local/Remote):642 / 27
Message 89 of 131
stats look ok apart from high noise margin and lower speed.  just complete email following contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
RipandBurn
Message 90 of 131
Thanks Olga - reset gone ahead and errors seem to be settling down.  Sure it won't stay at this level/fast path but if it is like before it will settle but slightly slower - but still a lot better than before (noticably so!)
ADSL Line Status
Connection time:0 days, 02:47:47
Downstream:5.656 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):6.1 dB / 20.0 dB
Line attenuation (Down/Up):44.2 dB / 28.0 dB
Output power (Down/Up):19.7 dBm / 11.9 dBm
CRC Events (Down/Up):299 / 49
HEC Events (Down/Up):1048 / 0
Error Seconds (Local/Remote):1316 / 69
