Moderator
Moderator
Message 11 of 17
Re: Strange Noise Margin
Hi @zJ and thanks for keeping us up to date.
Can you please send me over your details and I'll look into getting the SNR reset for you. You'll get the contact the moderators link in my profile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
zJ
Message 12 of 17
Ok, just did that now.
Thanks for everyones help
Moderator
Moderator
Message 13 of 17
Thanks for letting me know @zJ.
We're very busy at present so it's taking longer than expected to reply but once you submit the details we'll get to you in turn.
Cheers
David
Kudos”Kudos”
zJ
Message 14 of 17
My broadband light just went out and returned back to blue, so I logged on to find this:
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:01:43
Downstream:14.07 Mbps
Upstream:1.22 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):6.0 dB / 6.8 dB
Line attenuation (Down/Up):26.6 dB / 15.6 dB
Output power (Down/Up):19.2 dBm / 11.8 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):0 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 0
Error Seconds (Local/Remote):4 / 13764
Thank you to everyone who helped
Ratings for all!
zJ
Message 15 of 17
It looks like you came out of the banding automatically now you just need to maintain a stable 24/7 connection and no turning the hub on and off manually as the will put you back were you were again
zJ
Message 16 of 17
UPDATE in Response to missed call:
Been connected for around 5 days no, very stable but unfortunatley my wife seems adamant about turning it off when she feels it neccessary (ie. kids wont go to bed). Other than that I'm very please and i say that the issues is fully resolved#
ADSL Line Status
Connection time:0 days, 12:42:34
Downstream:13.4 Mbps
Upstream:1.24 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):6.8 dB / 6.9 dB
Line attenuation (Down/Up):26.5 dB / 15.3 dB
Output power (Down/Up):19.3 dBm / 11.9 dBm
FEC Events (Down/Up):0 / 50168
CRC Events (Down/Up):557 / 20891
HEC Events (Down/Up):3147 / 7020066
370 / 14013
Message 17 of 17
hopefully you avoid the banding the turning off will not help the connection have you tried the parental controls they may help
