sswales
Message 11 of 16
Re: Strathtay exchange moved to ADSL2+ overnight - connection profile messed up
Oh dear, oh dear. DLM does not seem to have got a handle on this line. Three weeks later and we are back down to 2272 kbps capped profile at 10dB margin (which also reports a current max achievable rate of 3649 kbps). Is it possible for the line cap to be removed please?
Message 12 of 16
the banding of your conenction normally only happens when there is a problem with your connection  are you dropping your internet hence the banding  can you post your router stats please
unless the underlying problem is fixed then banding will happen again just it has done now
sswales
Message 13 of 16
Thanks - it is a venerable 2wire BT2700HGV; as you can see after a reset it was happy enough (as was I) at 3824 kbps on 9dB interleaved and just goes downhill. There is zero prospect of this line ever being problem-free as it is 4km of above-ground line. I would prefer speed over stability - it is now worse than when it was on ADSL Max.
Troubleshooting – DSL Diagnostics
General Information
DSL Line (Wire Pair):Line 1 (inner pair)
Downstream Rate Cap:2272 kbps
Downstream Atten. at 300kHz:59.8 dB
Uncancelled Echo:-21.4 dBOk
VCXO Frequency Offset:-2.0 ppmOk
Final Rx Gain:34.5 dBOk
Impulse Noise Comp. Tones:0Ok
Excessive Impulse Noise:0Ok
Impulse noise protection:4.92
Delay of latency path:8.00 ms
Training History
 Downstream Upstream
TimeLine RateMax1Max2Max3Mgn1Mgn2AttnPwrCRCsFECsINPDLY RateMaxMgnAttnPwrCRCsFECs ModeVendorStateExit CodeEchoVCXORx GainINC Tones
2018/05/08 08:32:10 BST1 38243781372537259.08.762.018.0597103311.008.00 44662411.339.012.122270 G.DMT2+ Annex ABroadcom230/105ERR_LOS_LIMIT-21.3-0.734.50
2018/05/10 08:20:09 BST1 38223725388938899.310.162.518.093458541.007.97 5355419.739.512.1107442 G.DMT2+ Annex ABroadcom230/105ERR_LOS_LIMIT-21.0-0.534.50
2018/05/15 08:25:12 BST1 39203885381738179.08.761.718.02617720811.208.00 6446345.938.712.115172776 G.DMT2+ Annex ABroadcom230/105ERR_LOS_LIMIT-21.2-0.334.50
2018/05/18 13:36:28 BST1 338332613081308112.011.062.017.8379128611.127.98 6486245.339.012.111177883 G.DMT2+ Annex ABroadcom230/105IDLE_REQUEST-20.3-0.734.50
2018/05/19 10:37:39 BST1 320030733149314912.012.662.917.81112771.048.00 6376376.139.812.106159 G.DMT2+ Annex ABroadcom230/105IDLE_REQUEST-20.8-1.034.50
2018/05/28 09:38:52 BST1 339932653017301712.010.562.717.9258462092301.127.98 6316245.939.712.1128127045 G.DMT2+ Annex ABroadcom230/105IDLE_REQUEST-16.5-0.734.50
2018/05/28 16:00:53 BST1 318730572869286912.011.062.917.81628181.057.99 6376205.639.912.1116058 G.DMT2+ Annex ABroadcom230/105ERR_LOS_LIMIT-20.6-1.734.50
2018/05/29 10:56:06 BST1 251224012553255315.015.863.717.38078151.138.00 5986136.640.612.128393 G.DMT2+ Annex ABroadcom230/105IDLE_REQUEST-20.2-2.334.50
2018/05/30 10:40:26 BST1 265925492401240115.013.962.617.51023127361.077.99 6346145.339.512.11513452 G.DMT2+ Annex ABroadcom230/105ERR_LOS_LIMIT-20.5-2.134.50
2018/05/30 11:25:13 BST1 227236813649364910.210.264.517.60814.928.00 6316306.140.612.111522 G.DMT2+ Annex ABroadcom229/103N/A-21.4-2.034.50
Message 14 of 16
from the stats you are not going to win until you can get a more stable conenction    even with the noise margin increasing which should have helped stability you are still getting resets daily recently and ending up in banded profile
the old '2 wire' was supposed to give better results but I found an old netgear gave me better results  have you tried one of the newer hubs like the hh4 to see if that makes any difference?
sswales
Message 15 of 16
It seems that the ADSL2+ DLM is degrading the profile very quickly, unlike when it was on ADSL Max (happy at 3500+ kbps 6dB fastpath for ages, until there were real line problems like knackered joints, shot line).
I never really used the HH4 as its sync was very poor (1700-2100) in comparision to the 2 wire on my line when on ADSL Max, often to the point of being unable to sync at all. I did use a Netgear DG534 at one point but that was no better than the HH3 I had before as my backup router.
I have now reconnected using the HH4 (limited to 2272 as expected) and will see what happens in a couple of weeks! Fingers crossed...
Message 16 of 16
see how it goes and post back if not helping
I thinkit was an old netgear dg834gt I had but with custom firmware which enabled me to alter the noise margin to suit my connection
