MYKEU
Message 1 of 20
Switching to fastpath profile
Hey,
Is it possible for a moderator to change my line to the fastpath profile?
I have read somewhere that I need to post on here in order to receive an invite to contact the moderators.
Kind regards,
Michael
19 REPLIES 19
Message 2 of 20
Re: Switching to fastpath profile
Can you post the stats from your hub
MYKEU
Message 3 of 20
Hey,
As far as I am aware, I have the Home Hub 4 and there are no line stats on the hub page.
Message 4 of 20
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
MYKEU
Message 5 of 20
I had to look quite far back but I have found this that is similar to what you stated;
17:43:24, 28 May. PPP LCP Send Configuration Request
17:43:19, 28 May. DSL Link Up: Down Rate=19419Kbps, Up Rate=1275Kbps; SNR Margin Down=6.1dB, Up=6.6dB
Message 6 of 20
your router reset last night was that a manual reset or router dropping connection?
MYKEU
Message 7 of 20
Hey,
No this is the first time that I am using this router.
That being said, my internet dropped out just now and came back up ~2mins later. When I check the logs, it now states;
DSL Link Up: Down Rate=8128Kbps, Up Rate=1184Kbps; SNR Margin Down=9.6dB, Up=7.0dB
My down rate is considerbly lower than before now - anybody know why this has happened?
I am assuming considering I only just acitvated my broadband, I need to wait a couple of days for it to see which is the best line? If so, does it normally lower my down rate this much while testing?
MYKEU
Message 8 of 20
I'll assume it is considering it happened again but this time it is now;
DSL Link Up: Down Rate=8128Kbps, Up Rate=1152Kbps; SNR Margin Down=9.5dB, Up=8.0dB
Message 9 of 20
you will need to be able to show at least 3 days+ stable connection before the mods would consider switching you to fast path
MYKEU
Message 10 of 20
I have had a quick check today and my hub is saying;
DSL Link Up: Down Rate=19376Kbps, Up Rate=443Kbps; SNR Margin Down=6.1dB, Up=33.4dB
However, my down rate is far from 19mb as when I test my line, it is only running at ~6mb.
Has my up rate got anything to do with this as for some reason it is at 33.4dB margin...
WBC ADSL 2+Up to 22--21 to 23Available
WBC ADSL 2+ Annex MUp to 22Up to 1.521 to 23Available
ADSL MaxUp to 7.5--6.5 to 8Available
WBC Fixed Rate2----Available
Other Offerings
Copper Multicast------Available
It appears that my line is suddenly on ADSL Max? Is this still because my line is adjusting itself? As I did receive a phone call last night informing me that my line is being switched to fastpath.
