holme1203
Newbie
Message 1 of 8
Terrible Service
Router keeps disconnecting from all devices, paying for a service that is not delivered. If i wasn't partway through a crucial piece of work i would leave immediately ( its taking at least30 mins on each occasion restarting router, devices and several attempts to connect frustrating ). I know that it is not a specific device problem, it is affecting i pads, phones, think pads, desktops in the house hold.
To sum it up "unsatisfactory" and i have given up on the telephone service desk
7 REPLIES 7
Message 2 of 8
Re: Terrible Service
Welcome to this user forum.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
holme1203
Newbie
Message 3 of 8
Thanks for the advice, just ran the test and all quiet between the announcements.
Message 4 of 8
Which BT Home hub do you have?
Try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating and renaming the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
Moderator
Moderator
Message 5 of 8
Hi @holme1203 ,
How are things with your connection? Have you had a change to try what @Keith_Beddoe  has suggested?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
kinetic747
Message 6 of 8
I've had a HH6 since it's introduction and it's flakey at best. It's been replaced twice and can work flawlessly for several months without issue. Sooner or later though it starts randomly disconnecting despite changing nothing, very frustrating.
Moderator
Moderator
Message 7 of 8
Hi @holme1203  Did you manage to get this resolved and if so how did you resolve it.
cheers
John
Community ModeratorJohnC
Kudos”Kudos”
Moderator
Moderator
Message 8 of 8
Hi @holme1203 ,
It’s been a awhile since you posted. Have you managed to get this sorted?
@kinetic747 Thanks for posting. Can you maybe start a new thread and post more details on the issue you’re having. I’m sure we’ll be able to offer some advice.
Cheers
David
Community ModeratorDaveM
Kudos”Kudos”
