Message 91 of 116
Re: Test socket, speed shot up then down
I would say you probably have a faulty home hub. Do you have another ADSL router you can try?
Elhadi
Message 92 of 116
No i do not,
If it is faulty should BT send me another one?
Thanks,
Message 93 of 116
Its the only thing you can try, but you will have to contact the broadband helpdesk, and say that your hub is faulty, as it keeps resetting itself.
They should send a repacement, and a returns box to send the old one back.
I think you have tried everything else.
Elhadi
Message 94 of 116
Okay thanks Keith,
So i just ring them up and explain?
Message 95 of 116
certainly sounds like hub on it's way out so phone CS and ask for a new hub.  are you still in contract with BT?  if so then you should get a replacement free  just tell them all the things you have done and hub still drops conenction
08001114567
Elhadi
Message 96 of 116
Yes i am in a contract with BT i will ring them up and ask now.
Elhadi
Message 97 of 116
I had a long conversation with bt and they are going to send me a BT Home hub 3 🙂
Hope it fixes it, i will get back in touch when i have the new hub installed,
Thank you guys!
Message 98 of 116
just post back when you get new hub connected with new stats  hopefully this will help along with all the other work you have done to improve your connection
Elhadi
Message 99 of 116
Got it set up 🙂 Also i have seen a huge change in bt trucks around my area and the checker has updated to October 2013 🙂
I will post back in 3 - 5 days when it is fixed 😄
Stats:
Line state:Connected
Connection time:0 days, 00:40:26
Downstream:5.992 Mbps
Upstream:1.062 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):15.0 dB / 6.1 dB
Line attenuation (Down/Up):35.9 dB / 19.7 dB
Output power (Down/Up):20.2 dBm / 12.3 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):13 / 36
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):70 / 11
Error Seconds (Local/Remote):8 / 3
Message 100 of 116
once you get the 3+ days then you can see if mods will reset your noise margin to 6db which will give you faster conenction speed
