Elhadi
Message 101 of 116
Re: Test socket, speed shot up then down
Oh i thought it would happen automatically, anyway okay ill post back in 3+ days 🙂
Message 102 of 116
it will happen automatically but could takes a few weeks rather than days
Elhadi
Message 103 of 116
Okay done 🙂
Also i had a little convo with a engineer "operating" on my cabinet and he told me really good news 🙂 hopefully infinity will be added this month,
so what should i do now i have 3 days +
Line state:Connected
Connection time:3 days, 09:56:24
Downstream:5.711 Mbps
Upstream:988 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):15.6 dB / 11.4 dB
Line attenuation (Down/Up):35.7 dB / 19.7 dB
Output power (Down/Up):20.3 dBm / 12.6 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):490 / 1277
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):2150 / 799
Error Seconds (Local/Remote):410 / 435
Message 104 of 116
great now you have the 3 days showing conenction stable the mods will post a link to contact them and then get your noise margin reset to 6db which will increase your conenction speed  contact mods link.jpg
Elhadi
Message 105 of 116
Well i was talking to bt about getting a new vision controller and i had to reset bt vision which led to the hub resetting do i have to wait another 3 days ? 😞
Message 106 of 116
no the stats showing the 3+ days is ok
Message 107 of 116
as you have posted 3 days + you should be ok when the mods read your post
Elhadi
Message 108 of 116
Cool, Thanks i will send the email now
Elhadi
Message 109 of 116
Also one last question before i send an email, how long will it take for it to be reset?
Message 110 of 116
you need to wait for mods to post which will give you access to the link - do not send PM as that will not get to the mod queue
once you complete the email you are then in a queue of other customers waiting for mod help and it can take 3/5 working days for mods to reply
